I had a 2Xi and tried using it on my new 7Dii with my 400DO f/4, which gave me 800mm that would auto-focus with the center point, wow. The results were quite poor and I discovered that the 2X version i electronics do not support MFA, which my rig needed. So, I bought a 2Xiii. In addition to the MFA capability, I think the optic quality is also improved. I do have to stop it down to get a sharp image, but I had to do that with my 1.4Xiii as well. I can tell you that the difference between 560mm focal length and 800mm focal length is quite significant when photographing small birds. It also requires careful technique and faster shutter speeds when handholding. I need a lot more practice. These are two images from my very first outing at Brazos Bend SP with the 2Xiii. Both are considerable crops. When our weather improves, I will be trying this setup some more, probably stopped down a bit more. I have added some additional mfa, as well.
Image hosted by forum (
714641)
© mikeivan [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. Image hosted by forum (
714642)
