FORUMS General Gear Talk Data Storage, Memory Cards & Backup
Thread started 25 Feb 2015 (Wednesday) 21:55
Lexar CF 800x vs 1066x
Tim ­ Barnhart
Joined Jan 2013
Post edited over 8 years ago by Tim Barnhart.
Feb 25, 2015 21:55 |  #1
Is there a huge difference? What I really should say is, is there a noticeable difference? I will be using in a 1D4 and often times I am on a tight deadline to get images submitted
Thinking about getting one of their cards, I am still using Sandisk Extremes 16GB 60MB/s cards. Will also pick up the lexar dual bay cf/sd usb3 reader when I pick a card
Canon 1D mark IV | Canon 1D Mark III
Canon EF 24-105L | Canon EF 300 f4L IS
Canon 85mm f1.8
John ­ from ­ PA
Joined May 2003
Feb 28, 2015 16:51 |  #2
When you get the dual slot reader you might havecto go to http://www.lexar.com/s​upport/downloads (external link) and update the driver. Once there scroll down and pick the driver based on your OS. I know some people had issues reading some SD cards, and the driver update was the fix. Also possible this isn't applicable to the CF card but an up to date driver generally is a good idea.
marcuswy
1 post
Joined Feb 2015
Mar 03, 2015 11:50 |  #3
I've got a bunch of 800x and 1000x Lexar CF cards and can't say that I've ever seen a noticeable difference in write times between them when in my 5D3.
virsago_mk2
Mar 04, 2015 00:06 as a reply to  @ marcuswy's post |  #4
I do not have Lexar CF cards but I have other CF card brands at 800x, 900x & 1000x.
To be honest, unless you shoot long RAW burst or long videos, you won't notice any difference on the buffer speed between 800x & 1000x.
Transfer speed to PC also depends on your USB type too. Obviously USB 3.0 is the fastest but again it won't make much different on 800x & 1000x.
Gear: Here | Portfolio: Flickr (external link)
Tim ­ Barnhart
Joined Jan 2013
Mar 05, 2015 08:34 |  #5
I shoot raw to cf and jpeg to sd so at 10fps I am throwing down raw files like crazy
Canon 85mm f1.8
Vladdo
Joined Apr 2013
Mar 06, 2015 04:33 |  #6
the lexar 800x speed cards have a really horrible write performance, so much so, they're not much better than my generic 233x write cards..
that said, the lexar 1066x are vastly faster.. both in terms of read and write speeds... and yes, usb 3 card readers are the way to go.
My Website (external link) | My Facebook (external link) | My Books (external link)
chantu
Mar 13, 2015 14:40 as a reply to  @ Vladdo's post |  #7
Here's an interesting read:
http://www.cameramemor​yspeed.com …st-sd-cf-card-comparison/ (external link)
Surprisingly, there a big difference between 800x and 1066x. The marketing folks probably named the 800x card.
Tim ­ Barnhart
Joined Jan 2013
Mar 13, 2015 15:51 |  #8
Thanks, I also saw that Lexar came out with even faster cards now...
Canon 85mm f1.8
SilentRampage34
Mar 27, 2015 15:13 |  #9
Whether or not there is a difference depends on your needs and bottlenecks. The two numbers besides capacity that matter for any SD or CF card are minimum write speed and minimum read speed.
Write speed matters when you're shooting. The better (faster) the minimum write speed, the faster your camera you write new files to the card. This matters when shooting in bursts where the camera may be taking photos faster than the card can write them and eventually will have to slow down how fast it's shooting to wait for the card to catch up. The Lexar 800x cards have a minimum write speed of 20MB/s which gives my 7D up to about 22 raw shots before it has to slow down. The 1066x cards have a minimum write speed of 65MB/s which should give me triple the shots or better.
Read speed matters when reading the cards to copy somewhere else. The faster the read speed of the card, the faster files can be copied to another storage medium (such as another card, an HDD, or an SSD). However, you now have to deal with the minimum write speed of the new storage device. For an HDD this usually maxes out at about 120MB/s, but can be as low as 40MB/s. For an SSD the write speeds are usually faster, but it depends on the exact model. The minimum read speeds on the 800x are "up to" 120MB/s and 1066x goes "up to" 160MB/s.
In short: if you often find yourself waiting on the buffer to clear so you can shoot more, definitely get the 1066x. If you are waiting on the cards to write to an HDD, probably stick with 800x. If you use an SSD, then probably get the 1066x.
Nogo
POTN record for # of posts during "Permanent Ban"
Gallery: 17 photos
Joined Dec 2013
Post edited over 8 years ago by Nogo.
Mar 27, 2015 15:22 |  #10
Tim Barnhart wrote in post #17473632 (external link)
Be careful with this. The cards that are way faster are CFast cards. That is a different standard. Most DSLR cameras can not utilize that standard and because they are so much more expensive, you are just wasting your money buying them unless your camera is made for the new standard.
Philip
eelnoraa
Mar 31, 2015 16:54 |  #11
SilentRampage34 wrote in post #17494500 (external link)
Lexar 800x card does NOT have a min write speed of 20MB/s, 1066x does NOT have a min write speed of 65MB/s. There is no such a spec because the minimal depends on what you are writing to it, and can NOT be garranteed. No card manufacture can put such a spec on paper.
Further more, Lexar 1066x does NOT necessary write at 160MB/s. The "transfer speed" is 160MB/s, it applies to the maximum read speed. If you look at it carefully, there is usually "write slower" written somewhere. Usually, the write speed can match the read speed on higher capacity card. For lower capacity, like 16GB, no, write can't be 160MB/s simply because there isn't enough parallels
5Di, 5Diii, 28, 50, 85, 16-35II, 24-105, 70-200F2.8 IS
eelnoraa
Mar 31, 2015 17:07 |  #12
Nogo wrote in post #17494510 (external link)
Cfast was supposed to be the replacement of CF. CF uses UDMA interface. The most current is UDMA7 which has max data rate of 166MB/s. That is why you see those high end CF, Sandisk Extreme Pro or Lexar 1066 claim "transfer speed" up to 160MB/s. It is interface limited. And it usually applies for read, not write.
CFast is on SATA interface, with bandwitch of 6Gbit/s or 550MByte/s. It is exactly like HDD/SSD interface in computers. In fact, most CFAST is nothing more than a SSD with a different connector and in a very smaller form factor. The reason CFast hasn't taken off is mainly due to lack of practical need for these kind of speed in photography application. Still cameras are NOT going to write data in such a high speed. 1080P video doesn't need that speed either. What come with this speed is power consumption. The only big customer for CFast today is those Arri, black magin, ... high end, high resolution video recording in RAW format.
hollis_f
Apr 01, 2015 03:47 |  #13
Except that it will not. The 7D doesn't actually write to the card until it fills the buffer. I have repeatedly posted my test where I compared various CF cards, all the way down to 1 MB/s, and they all managed a burst of 24 shots before slowing down.
There is, however, a massive difference in the time taken to clear the buffer (from 10s to over 3 minutes).
Frank Hollis - Retired mass spectroscopist
Give a man a fish and he'll eat for a day. Teach a man to fish and he'll complain about the withdrawal of his free fish entitlement.
Gear Website (external link)
Aswald
Joined Oct 2013
Apr 01, 2015 04:45 |  #14
Tim Barnhart wrote in post #17461603 (external link)
Go for the 1066x cards. It clears up the buffer faster than the 800x cards.
It was noticeable for me as I sometimes hit the buffer limit. If you don't hit the limit, then both cards are fine.
SilentRampage34
Apr 04, 2015 22:19 |  #15
eelnoraa wrote in post #17499697 (external link)
Per Lexar's website.
http://www.lexar.com …l-1066x-compactflash-card (external link)
IMAGE: http://i.imgur.com/nizzrJY.png
Granted, the VPG spec as defined by the Compact Flash Association is intended to define the minimum write speed for sustained video capture, it stands to reason that if they card can continuously write video at a given speed, it ought to be able to write photos or other files at that speed. And to be clear, I never claimed the 1066x could write at 160MB/s, only that Lexar claims it meets the requirement of VPG-65, which states it can write video files at 65MB/s. I thought I was very clear that the 160MB/s was in reference to read speed as a maximum, which doesn't matter much beyond about 110MB/s unless you're reading from the card and writing to an SSD.
hollis_f wrote in post #17500294 (external link)
I checked up on the test you refer to, I see it was done in January 2011. There is the issue that an entirely new firmware was released since that testing, meaning very different buffer behavior. However, the idea that you state the 7D doesn't write to the card until it fills the buffer simply isn't true. It makes no sense that images wouldn't be writing to the card until the buffer is full. This is disprovable by taking a burst of say five images, far fewer than the 20-25 that the 7D can buffer, and watching the buffer clear while no more images are taken.
12,776 views & 1 like for this thread, 12 members have posted to it and it is followed by 6 members.
1507 guests, 130 members online
