If you have you have used an extender either 1 1.4 or 2X (Canon or other) can you share your experience? Does it have to be a Canon TC? I heard some very good things about the Kenko pro...
Feb 27, 2015 19:12 | #1 If you have you have used an extender either 1 1.4 or 2X (Canon or other) can you share your experience? Does it have to be a Canon TC? I heard some very good things about the Kenko pro...
DreDaze happy with myself for not saying anything stupid More info Post edited over 8 years ago by DreDaze. | Feb 27, 2015 19:53 | #2 |
135L - my kids sports. they are only 9 and 6...
Feb 27, 2015 22:48 | #4 I own a 100-400 and a 5DIII which retains center point AF with the 1.4x extender. I rented the Canon TC 1.4x III and took some test shots of a wall map across the room and some birds at the local wetlands. In both cases the shots without the TC, cropped to match the FOV with the TC, were actually sharper than the shots with the TC. For birds in flight, losing the extra AF points made catching focus that much harder. For me, at least with this lens, the TC wasn't worth it.
MalVeauX "Looks rough and well used" More info | Feb 28, 2015 01:57 | #5 vargasjv wrote in post #17452979 If you have you have used an extender either 1 1.4 or 2X (Canon or other) can you share your experience? Does it have to be a Canon TC? I heard some very good things about the Kenko pro... Heya,
yogestee "my posts can be a little colourful" More info | Feb 28, 2015 06:02 | #6 I've had a Tamron SP 1.4x TC (the white model) for years. I think Kenko make an exact replica now. I don't use it all that much but when teamed up with certain lenses the results are very good to excellent. Works great with my 135L and Sigma 50-150mm f/2.8 non OS. Jurgen
Sounds like the Kenko PRO 300 Series DGX might be what I need!
jimewall Goldmember 1,871 posts Likes: 11 Joined May 2008 Location: Cleveland, Ohio More info | Feb 28, 2015 06:59 | #8 I have the older Kenko Pro 300s - both a 1.4x and a 2X. I also have a Canon 1.4X II. The Canon and the Kenko 1.4X give near identical results. I occasionally use the 1.4X on any of my longer lenses, but my 150-500mm Sigma doesn't seem to like TCs much (often seems too soft (even if used on a tripod, to lessen user error). Thanks for Reading & Good Luck - Jim
| Latest registered member is Niagara Wedding Photographer 1220 guests, 117 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
