I have 2 YN 560 Mark IVs. So far no QC problems with them, unless you count the Engrish in the users manual. Can someone please explain this feature and why a photographer would use it over the other modes? Thanks.
Feb 28, 2015 16:19 | #1 I have 2 YN 560 Mark IVs. So far no QC problems with them, unless you count the Engrish in the users manual. Can someone please explain this feature and why a photographer would use it over the other modes? Thanks.
oldvultureface Goldmember More info | Feb 28, 2015 17:00 | #2 Multi is a stroboscopic effect. You set the number of flashes and the frequency, i.e., 10 flashes at 5 Hz. Leaving your shutter open for two seconds with a moving subject in the frame would give you an interesting effect.
Interesting. I don't know what stroboscopic effect is and flash power expressed in terms of Hz is new to me also. I understand the progression of stops but Hz is new.
oldvultureface Goldmember More info Post edited over 8 years ago by oldvultureface. (2 edits in all) | Hz is cycles per second. The above example would make the 560 flash 10 times in two seconds, five times in one second (5 Hz) for two seconds for a total of ten flashes at the manual power you set.
CliveyBoy R.I.P. He will be missed 3,272 posts Likes: 42 Joined Nov 2005 Location: Tauranga, NZ More info | Feb 28, 2015 18:18 | #5 "Multi" is handled by the 622Cs, but only to copy the Canon camera output. The concepts and settings are described in the EOS camera manuals. Clive, and Great G/D Abbie
MedicinSC Goldmember More info | Feb 28, 2015 21:01 | #6 Silver-Halide wrote in post #17454150 Interesting. I don't know what stroboscopic effect is and flash power expressed in terms of Hz is new to me also. I understand the progression of stops but Hz is new. This is stroboscopic photography. https://www.google.com …0CB4QsAQ&biw=1366&bih=682
| Latest registered member is semonsters 1504 guests, 136 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
