Thread started 01 Mar 2015 (Sunday) 18:55
Pixma Pro 9000 Mark II issues with deep blacks.
Drakeskakes
Mar 01, 2015 18:55 |  #1
I changed the cartridges, I switched back to OEM ink, and ran multiple cleanings and deep cleanings. I still can't get the blacks to show properly. The deep blacks so blue. Yes, I made sure the cartridges were in the right slots =P
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/03/1/LQ_715495.jpg
Image hosted by forum (715495) © Drakeskakes [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/03/1/LQ_715496.jpg
Image hosted by forum (715496) © Drakeskakes [SHARE LINK]
"Nobodys built like you....
.... You design yourself"
www.NeillDrake.com (external link)
Gripped 50D | 17-55 2.8 IS USM | Sigma 10mm 2.8 Fisheye | 100mm 2.8 Macro USM | Nifty Fifty | 430ex II | Timbuk2
Mark ­ Vuleta
Gallery: 48 photos
Mar 02, 2015 14:47 |  #2
If the cleaning cycles gave good results, try a head alignment and or a Nozzle Check to see if the black section of the print head is operating correctly.
I you have not been using Canon inks, it is possible that you may have damaged the print head.
-Douglas-
Beware of DOUG
Gallery: 151 photos
Mar 02, 2015 16:42 |  #3
You can also have a look through the Printer Knowledge forum (external link) to see
how to unclog your print head if it's not toast!
Edit My Images- OK"Brain Fart" = an essential bodily function.
tgara
Mar 02, 2015 21:36 |  #4
It's a well-known issue that the print heads in the 9000 do not play nice with non-OEM inks. Kids on your printer her probably toast. However, look on the bright side. You can now get yourself a brand-new PIXMA pro 100! ;-)a. Welcome to the modern world!
EOS 5D Mark III
EOS Rebel SL1
Full Gear List
Aswald
Joined Oct 2013
Mar 02, 2015 21:40 |  #5
Looks like your print head is stuck/faulty. Had similar issues with one of my canon printers. Took it back to Canon. Had to change the whole head. And cartridges too. They were originals.
Good luck.
1,125 views & 0 likes for this thread, 5 members have posted to it and it is followed by 2 members.
1119 guests, 171 members online
