Had so far over looked the ability to use flash , and 1/8000 shutter speed. Is anyone using this option,and for what. Would this be useful for bif ?
keeperseeker Cream of the Crop More info Post edited over 8 years ago by keeperseeker. | Mar 03, 2015 20:53 | #1 Had so far over looked the ability to use flash , and 1/8000 shutter speed. Is anyone using this option,and for what. Would this be useful for bif ? Never make a decision when you have to pee. L Cohen
Mar 03, 2015 20:58 | #2 Done some cheer shoots of friends, it works great. Put the sun at their back and shot away! 1DX, R5, 400 2.8 V2, 300 2.8L, 70-200 2.8L IS II, 24-70 2.8L, 300 2.8L IS, 200 2.8L, 7D, 40D, 100 2.8 Macro, 580EX II
Mar 03, 2015 21:12 | #3 The most useful time for it is dimming the ambient outdoors while adding light to a subject. The flash is quick enough to stop motion indoors. my gear: T4i - EF-s 17-55, Ef-s 55-250 is stm, EF-S 10-22 usm, ef 100mm 2.8 macro
crbinson Senior Member 614 posts Likes: 90 Joined Jul 2012 Location: OKC More info | Mar 03, 2015 21:13 | #4 Used HSS this past weekend. 600RT on camera. Kids at b-day party playing in a nearly dark bounce house party room. Seems like I was shooting with ISO 1600-3200 with SS in the 500-640 range, flash on ETTL.
MalVeauX "Looks rough and well used" More info | Mar 03, 2015 22:07 | #5 keeperseeker wrote in post #17459465 Had so far over looked the ability to use flash , and 1/8000 shutter speed. Is anyone using this option,and for what. Would this be useful for bif ? Heya,
M_Six Cream of the Crop More info | Mar 03, 2015 22:19 | #6 MalVeauX wrote in post #17459549 Heya, Not useful for BIF really. HSS flash is more like a continuous light than a strobe, and as the shutter speed goes faster, the power output of the HSS drops dramatically. At 1/500s you're talking very little flash output. And since light falls off over distance, very quickly, take a low power output and put that over a distance, such as a bird flying, and you'll find that it probably doesn't even do much for exposing the bird (even with a better beamer perhaps). That will be relative to distance though and how fast your shutter is. It's good if you wanted to use a wide aperture, and a fast shutter speed, and get some fill light, at close range. It's not good at a distance because again the power output is low in HSS at faster shutter speeds. For BIF, traditional 1/200s or 1/250s sync speed with ETTL flash is fine, with a better beamer. The duration of the flash stops motion so the slower shutter is not a problem. Take a look at examples of birding with flash extenders. They're not using HSS. Very best, Have to agree here. I tried HSS with a Better Beamer for birds at a feeder and the results were a bit disappointing. At any worthwhile distance, the flash was too weak. Mark J.
Mar 03, 2015 22:34 | #7 OK , MalV and M Six,,,,makes sense,,but disappointing. Never make a decision when you have to pee. L Cohen
MalVeauX "Looks rough and well used" More info | Mar 03, 2015 22:39 | #8 keeperseeker wrote in post #17459586 OK , MalV and M Six,,,,makes sense,,but disappointing. Heya,
M_Six Cream of the Crop More info | Mar 03, 2015 22:46 | #9 MalVeauX wrote in post #17459597 Heya, Get a better beamer, a good flash bracket to hold it off camera and use a TTL cable for off-camera flash, your HSS capable flash is definitely capable of ETTL. Use it in ETTL or manual if you know the exposure power setting you want/need. Setup on a tripod and start taking on birds. You can get great distance with normal flash with a better beamer. And again, 1/200s or 1/250s depending on your camera is enough even for something moving typically because it's the flash duration you're exposing, unless you just use it as fill (that's different). Stop down aperture for ambient light. Expose subject with flash. ISO again based on ambient light and power level needed from flash. The result is that you can make the ambient light darker by a few stops and expose your subject via flash, making those popping isolated images. No need for HSS. Very best, I don't want to sound like an echo, but again, I agree. I bought C shaped bracket that clamps onto the Arca-Swiss foot on my 400 5.6 and allows me to mount the flash and Better Beamer above the lens and well forward of the body. I use a cable back to the camera for ETTL. Not a rig you can walk around with, but great for backyard stuff or hanging out by a lock & dam. Mark J.
Mar 03, 2015 23:42 | #10 I use it for fill on sunny days when I need faster than 1/200 SS and am close enough to the subject. Mostly animal portraits thinking about it (not BIF). Edward Jenner
JeffreyG "my bits and pieces are all hard" More info | Mar 04, 2015 18:08 | #11 The purpose of HSS is to make it possible to shoot with flash in bright light. A typical application would be shooting a portrait outdoors on a sunny day. The combination of aperture you want to use (especially if you would like to get a bit of background blur) and the ISO floor of the camera (ISO 100 for Canon) may make it challenging to get under the sync speed. My personal stuff:http://www.flickr.com/photos/jngirbach/sets/
MalVeauX "Looks rough and well used" More info Post edited over 8 years ago by MalVeauX. (3 edits in all) | Mar 04, 2015 19:34 | #12 jay125 wrote in post #17460912 I use it for low key photography. This shot was taken in an office full of windows on a bright sunny day. The only illumination captured was from the flash which was positioned about 18 inches from his face. F32, 1/1000s, ISO 200. For reference, here's the same thing from this shoot at the same time of day and light, without the ND filters and without flash, to show how bright it was: IMAGE LINK: https://flic.kr/p/pEdKAC Very best,
Mar 04, 2015 19:35 | #13 Thanks for the enlighting replies! Not only a lot to learn,,,but a lot to remember to apply,,,once you learn it! Never make a decision when you have to pee. L Cohen
GeoKras1989 Goldmember More info Post edited over 8 years ago by GeoKras1989. | Mar 04, 2015 21:01 | #14 Permanent banTerryMiller wrote in post #17459494 The most useful time for it is dimming the ambient outdoors while adding light to a subject. The flash is quick enough to stop motion indoors. Sounds good, but exactly backwards. The flash is actually prolonged in HSS. It flashes repeatedly as the shutter exposes each passing very small segment of the sensor. That is why HSS consumes so much power. The faster the shutter, the higher frequency of flashes required. A flash a 1/8000 actually last 1/8000. A flash at 1/60 can be as fast as 1/25000. Which is how you freeze action with a flash and slow(ish) shutter speed. WARNING: I often dispense advice in fields I know little about!
Mar 04, 2015 22:37 | #15 GeoKras1989 wrote in post #17461054 Sounds good, but exactly backwards. The flash is actually prolonged in HSS. It flashes repeatedly as the shutter exposes each passing very small segment of the sensor. That is why HSS consumes so much power. The faster the shutter, the higher frequency of flashes required. A flash a 1/8000 actually last 1/8000. A flash at 1/60 can be as fast as 1/25000. Which is how you freeze action with a flash and slow(ish) shutter speed. I've use my 580EX II at 1/8000. At f/2.8 is good for about 6 feet. You ain't doing BIF with that.
Edward Jenner
| Latest registered member is semonsters 927 guests, 117 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
