I'm tninking of getting a NAS. I was wondering if I could get a four bay enclosure and use only two drives initially, running RAID 1. And then add another RAID 1 pair later.
Is this possible, and if so, do you have on which brand/model to get?
Mar 05, 2015 12:59 | #1 I'm tninking of getting a NAS. I was wondering if I could get a four bay enclosure and use only two drives initially, running RAID 1. And then add another RAID 1 pair later.
shocolite Senior Member More info | Mar 05, 2015 14:55 | #2 Hi, yes you can buy a 4-bay and start off with two drives. Most units should support this. Canon 80D, 700D & G7 X; EF-S 10-18/18-135 STM, EF-S 18-135 IS USM, 50 F1.4, 100 F2.8L Macro, 16-35 F4L, 70-200 F4L IS; 100-400 L II, Speedlite 430EX II
Many thanks for the reply!
shocolite Senior Member More info | The WD My Cloud EX4100 looks very good with it's specs. Canon 80D, 700D & G7 X; EF-S 10-18/18-135 STM, EF-S 18-135 IS USM, 50 F1.4, 100 F2.8L Macro, 16-35 F4L, 70-200 F4L IS; 100-400 L II, Speedlite 430EX II
kelvinj Senior Member More info Post edited over 8 years ago by kelvinj. (2 edits in all) | Mar 06, 2015 02:27 | #5 Hi I am also researching on upgrading my 2 bay nas to 4/5 bay nas due to capacity issue like you facing. So far I filtered down to either QNAP or Synology. QNAP is a bit more costly than synology but it got more features.
Mar 06, 2015 17:44 | #6 Many thanks for the replies! Going to look at smallnetbuilder now.
DiMAn0684 Goldmember 1,933 posts Likes: 13 Joined Dec 2009 Location: Boston, MA More info | Mar 06, 2015 23:51 | #7 kelvinj wrote in post #17462884 1 thing I learn from my network engineer though, make sure the hdds are from different manufacturing date .... if hard to ask, try purchase from 2 sources. Why ? So that the lifespan is different, wont spoil at the same time. if 1 failed (touch wood), the other will still survive. I'm a slightly different kind of engineer, but this sounds like BS. Having two devices with such lengthy life span within hours of one another is quite unlikely regardless of which batches they come from. Canon 5D MkII | Canon 16-35mm f/4 | Canon 50mm f/1.8 STM | Canon 24-105mm f/4 | Tamron 70-300mm VC | Canon 430EX II | Benro A2682TB1
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Actually it isn't. There are cases where manufacturers have gotten bad batches of resistors, capacitors, . . . which have led to widespread failure of the devices using them. By getting devices from two different batches you reduce the likelihood of having two drives blow at ore near the same time. Jon
DiMAn0684 Goldmember 1,933 posts Likes: 13 Joined Dec 2009 Location: Boston, MA More info | Mar 07, 2015 17:36 | #9 Jon wrote in post #17464579 Actually it isn't. There are cases where manufacturers have gotten bad batches of resistors, capacitors, . . . which have led to widespread failure of the devices using them. By getting devices from two different batches you reduce the likelihood of having two drives blow at ore near the same time. I understand the reasoning, and have seen certain batches of HDDs fail within a span of a few month in our R&D lab, but having multiple failures hours / days apart is pretty unlikely (in my opinion). Anyways, if you guys feel safer buying same model disks from different manufacturers that's fine by me Canon 5D MkII | Canon 16-35mm f/4 | Canon 50mm f/1.8 STM | Canon 24-105mm f/4 | Tamron 70-300mm VC | Canon 430EX II | Benro A2682TB1
amikhailny Hatchling 1 post Joined Feb 2015 More info | Mar 10, 2015 09:53 | #10 Here are my 2cents in this discussion - hard drives are easy to upgrade, but upgrading NAS is more expensive. So get the one with more bays than you need. If you need 2-bay, buy 4-5-6 bay system. Just get only 2 hard drives, and expand later.
Spats139 Senior Member More info | Mar 10, 2015 12:43 | #11 I just picked up the Drobo 5N and four 3TB drives; looking forward to getting it up and running. Might be worth a look. Dale
RileyNZL Senior Member More info Post edited over 8 years ago by RileyNZL. | Looking at a Drobo 5N or 5D myself, can't decide if I want the faster performance of 5D, or NAS features of the 5N. (N is network attached, D is direct attached via USB3 or thunderbolt). From what I've seen drobo offer the best features of most consumer NAS's, offering many features only available in enterprise NASes, but also at the same time lack some of the more consumer friendly features that synolgy/WD offer. Canon 1Dx |Canon 6D|Canon 24-70 F2.8 L MkII|Canon 16-35 F4 L|Sigma 70-200 F2.8 EX OS|Canon 400mm f5.6 L|Sigma 50mm F1.4|Canon 600EX's|Gitzo Explorer Tripod|
Mar 12, 2015 12:36 | #13 RileyNZL wrote in post #17471417 Looking at a Drobo 5N or 5D myself, can't decide if I want the faster performance of 5D, or NAS features of the 5N. (N is network attached, D is direct attached via USB3 or thunderbolt). From what I've seen drobo offer the best features of most consumer NAS's, offering many features only available in enterprise NASes, but also at the same time lack some of the more consumer friendly features that synolgy/WD offer. Also considering making my own using Windows Storage Spaces and ReFS (Software RAID on a very advanced file system), One big disadvantage of RAID 5 a lot of people don't consider, is if the hardware supporting it (the NAS itself) fails, often the data can't be recovered at all, particularly if the NAS you're using is no longer made/repairable. How much faster would the 5D be?
RileyNZL Senior Member More info | It depends on the drives you are using, bit the 5N is bottlenecked by the gigabit port, which is roughly 120MB/s, whereas users of the 5D, have achieved well over 500MB/s using SSD's, although at the end of the day your drives will affect speed. Many users of the 5N have reported actual speeds to be in 50-70MB/s range. Canon 1Dx |Canon 6D|Canon 24-70 F2.8 L MkII|Canon 16-35 F4 L|Sigma 70-200 F2.8 EX OS|Canon 400mm f5.6 L|Sigma 50mm F1.4|Canon 600EX's|Gitzo Explorer Tripod|
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Mar 12, 2015 14:52 | #15 Just read about Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
| Latest registered member is semonsters 1431 guests, 139 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
