I used to never use it, since I sharpen all of my pictures to my liking in post, but I used it recently a few times just to see the difference, and couldn't tell much. Why or why don't you use it?
| POLL: "Do you use sharpen for screen upon export in LR?" |
Yes | 10 76.9% |
No | 3 23.1% |
Not sure what you're asking | 0 0% |
JarvisCreativeStudios Goldmember More info | Mar 09, 2015 12:59 | #1 I used to never use it, since I sharpen all of my pictures to my liking in post, but I used it recently a few times just to see the difference, and couldn't tell much. Why or why don't you use it? WEBSITE
Mar 09, 2015 13:47 | #2 I use it cause it was on by default. My understanding is that in the final export since it is being resized you might need to resharpen it and this is what is going on here, nothing drastic. I come here for your expert opinion. Please do not hesitate to critique or edit.
ThreeHounds Goldmember More info | Mar 09, 2015 17:22 | #3 If by in post, you mean the detail panel in LR or in pre sharpener in NIK, that's actually input sharpening. Depending on what you're doing with the image, most could benefit from output sharpening on export to screen image or printing. 5D MkIII | 7D | Bronica ETRS
DanMarchant Do people actually believe in the Title Fairy? 5,634 posts Gallery: 19 photos Likes: 2057 Joined Oct 2011 Location: Where I'm from is unimportant, it's where I'm going that counts. More info | Mar 09, 2015 22:09 | #4 Jarvis Creative Studios wrote in post #17467497 I used to never use it, since I sharpen all of my pictures to my liking in post, but I used it recently a few times just to see the difference, and couldn't tell much. Why or why don't you use it? There are three types of sharpening; input sharpening, artistic sharpening and output sharpening. Dan Marchant
PaulieM Junior Member 23 posts Likes: 2 Joined Feb 2015 Location: Vermont More info | Mar 09, 2015 23:34 | #5 I sharpen on export, BUT sometimes it produces some awful results like jagged lines. Sometimes I export twice, once with and once without sharpening and compare images to look for over-processed artifacts.
BigAl007 Cream of the Crop 8,119 posts Gallery: 556 photos Best ofs: 1 Likes: 1682 Joined Dec 2010 Location: Repps cum Bastwick, Gt Yarmouth, Norfolk, UK. More info | Mar 10, 2015 05:37 | #6 When it comes to output sharpening in LR it also helps to ensure that all of your settings are appropriate for the final destination. The obvious ones are in the output sharpening panel in the various ways that you can export. What is not so obvious is that LR also looks at the output resolution setting that is applied. So if your are exporting for screen then you really should be setting an output PPI value commensurate with the type of dispaly you expect to be used. So for general web use I would normally set the output PPI value to 100, although I beleive that anything under about 150 will do. The only time I will export for screen with the output PPI set higher (200 PPI) is when I know that the image will be viewed only on a high res retina type display.
Mar 10, 2015 11:35 | #7 BigAl007 wrote in post #17468481 When it comes to output sharpening in LR it also helps to ensure that all of your settings are appropriate for the final destination. The obvious ones are in the output sharpening panel in the various ways that you can export. What is not so obvious is that LR also looks at the output resolution setting that is applied. So if your are exporting for screen then you really should be setting an output PPI value commensurate with the type of dispaly you expect to be used. So for general web use I would normally set the output PPI value to 100, although I beleive that anything under about 150 will do. The only time I will export for screen with the output PPI set higher (200 PPI) is when I know that the image will be viewed only on a high res retina type display. The value for PPI inserted in the EXIF data is still irrelevant for the actual display of the image file on screen once it has been created, but it affects the processing applied to the image on export. Alan
http://www.avidchick.com
Mar 14, 2015 11:45 | #8 Thanks for all the responses so far. Many of you are much smarter than me, and I'm not sure what all the terminology means lol. But keep the responses coming. I have been using the sharpen for screen (set on normal) more and more, and am pleased with the results. WEBSITE
Spats139 Senior Member More info | Mar 15, 2015 15:01 | #9 I don't use it, but after looking at this thread I'll give it a try to see if I can tell a difference. Dale
BigAl007 Cream of the Crop 8,119 posts Gallery: 556 photos Best ofs: 1 Likes: 1682 Joined Dec 2010 Location: Repps cum Bastwick, Gt Yarmouth, Norfolk, UK. More info | Mar 16, 2015 05:22 | #10 Spats139 wrote in post #17476211 I don't use it, but after looking at this thread I'll give it a try to see if I can tell a difference. I tend to find it makes the most difference when resizing on export. I can always tell when it's turned off.
Spats139 Senior Member More info | May 17, 2015 11:59 | #11 Not that I've been using it for a while, I'm liking the results. Dale
| Latest registered member is Sandro Bisotti 1611 guests, 159 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
