Thread started 11 Mar 2015 (Wednesday) 12:21
Virtual Lint Brush?
NewCreation
Gallery: 47 photos
Joined Jan 2013
Mar 11, 2015 12:21 |  #1
Shot an engagement session on Sunday and it's still snowy here in Michigan so the couple was wearing black coats. I realized as soon as I saw them that I need to add a lint brush to my camera bag but since I didn't have one at the time, I now have many photos in which I need to remove the lint. :/ Any way to remove all the lint more quickly that the healing tool in PS?
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/03/2/LQ_717035.jpg
Image hosted by forum (717035) © NewCreation [SHARE LINK]
My name is Brenda ~Saved by grace, walking by faith
http://brendahoffmanph​otography.com (external link)
Facebook (external link)
Redcrown
Mar 11, 2015 13:54 |  #2
Try the Noise/Dust&Scratches filter. Radius about 5 to 7. Definitely will erase the lint, but also the fabric texture. So then try adding back some texture. Sandstone works well sometimes.
Not a perfect solution, but perhaps the best compromise between speed and quality.
nathancarter
Gallery: 32 photos
Post edited over 8 years ago by nathancarter. (3 edits in all)
Mar 11, 2015 14:19 |  #3
Redcrown wrote in post #17470482 (external link)
There's a video on Lynda in which Chris Orwig uses a similar technique. Duplicate the layer, run the Dust&Scratches filter to get rid of the lint. Then, mask the whole repaired layer with black, and quickly swipe a white brush to reveal the "fixed" areas on top of the lint. That's still going to take a lot of time to get every piece of lint though. He used it on mud splatters on a child's face, and it worked well.
You MIGHT be able to do the mask automatically or semi-automatically instead of brushing it onto every little piece of lint. I feel like there should be a way to do it, but I'm not good enough to say exactly what. Here are a few thoughts for different methods...three different methods, not three steps to do in sequence:
- Select color range, then select only white areas (with some fuzziness in the selection) which should get all the white/light lint, then expand/feather the selection by 1px to make sure it gets everything, then fill that selection with white on the mask?
- Apply the luminosity of the original image to your mask, to reveal only the repaired image on the white lint areas? Then use a big brush to black out the rest of the mask everywhere except the sweater?
- Use one of the "Darken" or "Darker color" blend modes on the repaired layer, then do a big mask that reveals the whole sweater of the repaired layer?
NewCreation
Gallery: 47 photos
Joined Jan 2013
Mar 11, 2015 14:24 |  #4
Thanks for the suggestions. I will give them a try. Sure wish I had brought a lint brush with me. lol
kirkt
Post edited over 8 years ago by kirkt.
Mar 11, 2015 14:36 |  #5
The "Threshold" setting is your friend here. Here is your image run through Dust and Scratches at Radius 5 and Threshold 16. The hairs are much higher contrast than the underlying texture, so you can get a good threshold separating them, protecting the texture of the fleece and eliminating the hair. You can see wha the filter does to the larger clumps of hair, but if you edit to tone down the jacket, those blotches should not really be a nuisance.
I added some contrast to accentuate the result.
kirk
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/03/2/LQ_717052.jpg
Image hosted by forum (717052) © kirkt [SHARE LINK]
Kirk
NewCreation
Gallery: 47 photos
Joined Jan 2013
Mar 11, 2015 14:57 as a reply to  @ kirkt's post |  #6
Yay! This is awesome. Thanks for the help! Either I never knew or forgot about the dust and scratches filter. This will save me a ton of time. (Still packing a lint brush from now on, though.)
phantelope
Mar 11, 2015 15:33 |  #7
this tutorial is about quickly removing dirt from white seamless paper, might also be an option here?
https://fstoppers.com …ckgrounds-photoshop-32144 (external link)
40D, 5D3, a bunch of lenses and other things :cool:
NewCreation
Gallery: 47 photos
Joined Jan 2013
Mar 12, 2015 06:29 as a reply to  @ phantelope's post |  #8
Thanks for the suggestion. I will give it a go and see which solution is faster.
M_Six
Gallery: 68 photos
Mar 12, 2015 12:43 |  #9
kirkt wrote in post #17470543 (external link)
kirk
Genius. I just used your settings to fix a picture that's been bugging me for months. A kid showed up with a badly lint covered black fleece sweatshirt. It would have taken me hours to go through taking out all the lint. Using your settings I fixed it in 2 minutes. Neatest trick I've learned in a year.
Thanks, Kirk. I owe you one.
Mark J.
Gear
2,308 views & 0 likes for this thread, 6 members have posted to it.
Virtual Lint Brush?
875 guests, 162 members online
