I am thinking of getting one. But am confused, they say vibration is a biggy with huge sensors, and to combat this they have done 2 major things
i) strengthened the base plate for a more stable connecition to a tripod.
ii ) redesigned the mirror mechanisim to reduce mirror shake.
I am puzzled as its the same basic body, that they reduced the weight from 950g to 845g! A Very. BAD move IMO.
If stability is an issue why the hell would you do this.
Note if the reduction is 105 grams - thats an 11% reduction in strength/mass = stability no?
Actually its worse than that; if there is an additional reinforced baseplate ( with added weight ) then the general strength of the rest of the unit has had a weight = strength reduction of more than 11%!
OK my little **** over on to the real question.
This issue of needing to reduce vibration, which I guess could be classed as movement? Seems important. So What about motion blur, thats movement too eh?
Are Canon in effect saying to get the best out of it, one should use a tripod?
And more importantly will my 70-200L F2.8 II 's four stops of IS handle this "sensitivity" in a studio situation ?
I would destest it, if it meant in order to get the best IQ I need to use a tripod?
I am hoping there is a distiction between localised vibration inside the camera, and the general motion blurr caused by camera shake, induced by unsteady hands
Any views very much appreciated.
( if it does need a tripod
Then IMO this camera is totally useless, and its time to get a decent camera like a D810 )
That doesn't mean you have to use one. BTW, when the D800 came out I saw plenty of Nikon shooters on other boards freaking out about it, only to get one an realize it wasn't the big deal they thought it was going to be. The same discussions were had when the 5DII came out. People handhold 80mp medium format cameras, and they handhold 40mp cellphone cameras.
