FORUMS Photo Sharing & Visual Enjoyment Macro
Thread started 26 Feb 2006 (Sunday) 17:43
Best way to hand-hold while shooting insects...
d'mur
Joined Feb 2006
Feb 26, 2006 17:43 |  #1
My grasshopper just reappeared. He is no more than 1/4 inch long, but demonstrates to me just how tough this darn macro photography. So here is my issue.
I am using my 100mm macro lense with a couple of close-up filters attached so I can fill the frame with the little guy. However, my camera won't auto-focus with the second filter on, so I focus by moving the camera back and forth until my subject is in focus. However, between the slight shade, my hand-held camera and the mischieveous little breeze that seems to blow the second I'm ready to press the shutter, I can't quite get these pics as sharp as I would like. Any suggestions?
This picture is an example-I couldn't quite get his eyes in focus!
D
5D
17-40L
24-70L
100mm Macro
70-200 4.0L
Living proof that practice alone doesn't make perfect; sometimes you just need raw talent! :rolleyes:
d'mur
Joined Feb 2006
Feb 26, 2006 17:47 |  #2
Is this any better?
5D
17-40L
24-70L
100mm Macro
70-200 4.0L
Action_Man
Feb 26, 2006 17:59 |  #3
Brain (LordV) usually uses a pole to get stability, sometimes when i`m out and about i would pick up any old stick and use the same way Brian does, well attempt to anyway.
Nice images ...
racketman
Gallery: 16 photos
Feb 26, 2006 18:06 |  #4
that will be a Bush Cricket rather than a Grasshopper as such-although they can be called long-horned grasshoppers. True Crickets are less grasshopper like and drab colours.
Toby
Canon 5D MKIV & 90D
Olympus EM-1 MKII
Flickr collections (external link)
Gear
d'mur
Joined Feb 2006
Feb 26, 2006 18:19 |  #5
Racketman,
How does one tell the difference? I assume they are indiginous to So. Cal?
D
5D
17-40L
24-70L
100mm Macro
70-200 4.0L
Leorooster
Feb 26, 2006 18:22 |  #6
You're doing the right thing. Moving back and forth until it's in focus and then press the shutter. It takes some practice to to able to shoot handheld. As mentioned, Brian (LordV) uses a bean pole, and he has some amazing results. Some people here use tripod when shooting macros and the results are very good as well, but I, for one, just can be bothered with the set up. I instead use a monopod, which IMO helps a lot.
And, I think Racketman is correct that it's a cricket rather than a hopper. Nice shots though :)
Canon 1DMarkIII :shock: | Canon 5DII :p | Fujifilm Finepix F30
Glasses & Goodies
dpastern
Feb 26, 2006 20:16 |  #7
d'mur - I have exactly the same problem as you are having. I think it will come down a lot to how you hold the camera/lens, practice, more practice, and finding ways to make yourself more sturdy. Breathing techniques can help as well, apparently, you're meant to exhale as you depress the shutter button. Also, you're meant to gently roll your finger over the shutter button, rather than jerkily depressing it. Mirror lockup might help a bit as well...of course, failing that, use a tripod with something like a wimberley head (expensive, but apparently it's a very very good head).
Dave
LordV
Feb 27, 2006 01:04 |  #8
As mentioned above, I use a bean pole when shooting above 1:1 to help stabilise the camera (see pic below) but you really need a flash bracket for this to work as you grip the pole and flash bracket handle with your left hand. I use manual focus and the swaying technoique to focus and shoot whilst the camera is moving slightly- I find it very difficult to actually hold focus and shoot.
Other things that have helped are:-
1. Having a remote shutter button on the back of the flash bracket (by the left hand)- I found I was actually getting camera rotation when not using the pole when I pressed the shutter.
2. Using a monopod collapsed up and at right angles pointing back so you can rest it on your shoulder.
3. Taking many shots of the bug and trying to get different focus points- this is good practice and you normally find one of them will come out with the focus where you want it plus you may have the opportunity for focus stacking the shots.
Brian V
IMAGE: http://static.flickr.com/41/75900442_47fd4f3814.jpg
Macro Hints and tips
chemicalbro
Joined Jun 2005
Feb 27, 2006 02:28 |  #9
i usually stand with my legs about 2 feet apart for stability.... (use the swaying method of focusing,,, it's the tried and tested method) i put my right pinky under the body of the camera, index finger on the shutter (obviously) and the other 2 holding the grip (I suppose this depends on the size of your hands tho,,, I use a 350D which is small, so it's real easy for me to find a nice grip on it)...... i rest my pinky on the palm of my left hand (near the wrist) and hold the lens with my left fingers and pull my left arm in close to my chest (making your left arm a kinda monopod :)) don't tense your arm casue that will cause more shake than it solves..... relax,,,, move in out,,, when I get focus...FIRE...
i wouldn't recomend mirror lockup for handholding because you then have to press the shutter twice and on the 1st press it blacks out the viewfinder
As Brian also says, take LOTS of shots.... (my normal is about half a dozen per bug, one is bound to be in focus)
99.999999999999999 of my macro shots are handheld (like leo i can't be bothered with the tripod and i find that my monopod isn't versatile enough, it's easy enough to sway in and out but if you have to change the height of the pod by a few mm it's a different story, by the time you get the thing set up right your bug is long gone)
I just ordered a battery grip for it tho so i guess i'll have to modify my hand position (i really want the vertical shutter button tho and the extra battery life )
btw Brian , your cat is looking at you thinking (wtf is that crazy b***ard up to now, i wish he'd pay as much attention to me as he does to springtails ;))
Alan
LordV
Feb 27, 2006 02:36 as a reply to  @ chemicalbro's post |  #10
Hi Alan, :) :)
The cat is quite funny now- if he sees me pick up the camera, he goes to the back door to wait to go out with me :)
Only problem with this is he does like chasing the larger bugs if they are low enough.
Brian V.
chemicalbro
Joined Jun 2005
Feb 27, 2006 02:42 |  #11
I just had an idea for a new kinda monopod for macro while i was thinking about how to adjust height.
I'm gonna go model it in a 3d prog.........i'll post a pic of my idea when i'm done (maybe somebody would make me one :))
EDIT...... in fact maybe I'll patent the idea b4 i post a pic ;)
Alan
dpastern
Feb 27, 2006 03:06 |  #12
Brian, thanks for the tips, I shall have to try. Chemical, thanks for the tips as well, I think part of my problem is I've been holding onto the lens too tight, and shaking from the tension. Relax! I shall try this as well. The lots of shots is true as well, like anything, practice makes perfect. I fear I have a long way to go, but if I can get half as good as you guys, I'll be happy with myself :) I find shooting insects very relaxing and enjoyable.
Dave
Omri ­ Alon
Joined Nov 2005
Feb 27, 2006 04:52 as a reply to  @ LordV's post |  #13
LordV wrote:
Hi Alan, :) :)
Brian V.
My cat is kind of like yous :lol: :lol: Do you remember my toad pics? I had to put my cat inside to take those pics :D My cat also looks like yours. She makes a great model though :lol:
PHOTOBUCKET EMBEDDING IS DISABLED BY THIS MEMBER.
Photobucket sends ads instead of embedding photos from their free galleries.
Click the link (if available) below to see the image in a gallery page.
http://i22.photobucket​.com …20Choobee/CRW_8​862-01.jpg (external link)
Omri Alon | Flickr (external link)
Canon 6D
Samyang 14mm | 16-35L IS | Rokinon 24mm | 35mm IS | 85mm f/1.8 | 200mm f/2.8L | 430EXII
d'mur
Joined Feb 2006
Feb 27, 2006 10:02 |  #14
Great tips, thanks, everyone! I'm thinking the monopod idea will work best for me, since I can collapse it and use it when I am shooting from a sitting position (which is most of the time. I need to plant some taller bug-attracters!).
I like the pet info, too. I can't imagine life without my dog, although I have had to edit hair out of pics, and I found one on my focus screen. Grrrr...
5D
17-40L
24-70L
100mm Macro
70-200 4.0L
pxl8
Feb 27, 2006 11:34 |  #15
I use a monopod for low level stuff and find it very easy to work with. I keep the length short and sit crossed legged on the ground, resting the monopod on my leg. If the subject is a bit higher rather than extend the monopod I often bend over a bit and rest against the top of my thigh. I put a ball head on top of the mono so I can adjust the angle of the camera compared to the angle of the monopod. I did get a tripod at Xmas but I've yet to do any real shooting with it - I've got some plans for hoverflies this summer where the tripod will be ideal.
-- PXL8
1DmkIV, 5DmkIII + 135mm f/2L, 24-70mm f/2.8L, Sigma 35mm f/1.4
7,086 views & 0 likes for this thread
Latest registered member is abbeyroo
753 guests, 220 members online
