FORUMS Cameras, Lenses & Accessories Nikon Lenses
Thread started 12 Mar 2015 (Thursday) 19:32
20mm f/2.8d vs 24mm f/2.8d
kma16
Joined Feb 2015
Mar 12, 2015 19:32 |  #1
Has anyone used either the 20mm or 24mm f/2.8d lens? I'm looking use for landscapes as well as wide angle portraits.
thank you.
Nutmeger ­ Photos
Gallery: 6 photos
Joined Jan 2015
Dec 03, 2015 18:00 |  #2
I am on the fence about a landscape lens too. My current workflow is to use a Sigma 28-70 2.8 in a combination of HDR and panorama. It if far more complicated that using a dedicated lens.
Have you tired renting them before you buy?
BTH Photos
incrediblehark
Joined Jul 2015
Dec 19, 2015 19:22 |  #3
I owned the 20mm 2.8D and the 24mm 2.8 AIS, I believe the AIS and the D version are the same optical design so the results should be the same. The 20mm 2.8D was a good lens on both DX and FX for me. It's a great focal length and did well with portraits up close. The 24mm 2.8 AIS was better in terms of sharpness, but had less contrast then the 20mm, and wasn't as pleasing globally. I learned pretty early on that the 24mm 2.8 had some really nasty field curvature issues up close for portraits. I would not recommend the 24mm if you're going to be shooting people off center or relatively close up, it stretches faces a lot. I don't own either lens anymore, I upgraded to the new 20mm 1.8G and didn't need the similar focal lengths. If I was choosing between the 20mm 2.8D and the 24mm 2.8D, I'd go with the 20mm.
Hope that helps,
Adam
WildlifeGuy05
Joined Jun 2013
Jan 28, 2016 15:10 |  #4
I would go with the 20mm as well. I find it sharper, many more keeper shots with it vs 24mm. Keep an eye out for haze in the 20mm.
Mark ­ K
Gallery: 147 photos
Joined Jun 2013
Feb 16, 2016 08:46 |  #5
20mm was a great lens on my film bodies, FX90 etc. I ended up having another on newer dSLR bodies. However, this time this prime turns me down for lack of contrast and resolution. Newer lenses are always better. The 24 AIS, which I used only once, has become a permanent resident in my lens cabinet.
Canon, Nikon, Sony, Minolta, Fujifilm, Sigma, Tamron & Tokina
4,893 views & 0 likes for this thread, 5 members have posted to it and it is followed by 2 members.
1328 guests, 182 members online
