ssmanak wrote in post #17474362
Canon 28mm f 2.8 IS is perfect choice but I find it costly considering it will be seeing limited use. Will be using it on some occasions to reduce overall size of camera and for bigger aperture. Intend keeping 24-105.
Slow AF will do. Manual focus lens will be difficult to use on 6D at wide open aperture, however willing to give it a try.
I have canon 50mm f1.4. Therefore I do not wish to consider 35mm. Also find 24mm to be a bit lot wider for my liking
Do I have other options than canon 28mm f 1.8
Regards
Sudeep
Heya,
A second hand 28mm F1.8 would be great, usually around $300.
The 6D is excellent for manual focus lenses. Throw in an EG-S precision matte focus screen and it's easy as pie. Then you have a WORLD of classic manual glass, as 28mm was quite common, and you can find really good 28 F2.8 glass out there, like from Tamron & Super Takumar.
But really, F2.8 is not much faster than F4 really. And the 6D can handle the ISO to make up for the stop loss of light. And F2.8 on the wide end is not going to give shallow depth of field. You have your 50 F1.4 for that. If you want it to make a difference, I would just hunt a used 28 F1.8 so you get what you're paying for, fast AF, fairly sharp wide open (very sharp stopped down), not a huge lens, good wide aperture.
Very best,
