Thread started 14 Mar 2015 (Saturday) 15:39
7D Mark II Surprise Exposure & WB shift
sagebrush
Joined Dec 2001
Post edited over 8 years ago by sagebrush.
Mar 14, 2015 15:39 |  #1
I've taken hundreds of shots with my 7D2 over the last few weeks of youth basketball in the same gym (lighting), same camera setup, and same lens (135mm f2.0). The results have been great. I shot AF using AL SERVO/ Hi Speed frame rate and at a burst of 2-6 frame/burst. However last week I started to notice a problem. A noticeable shift between shots while no change in lighting that could effect exposure or AWB. Does anyone have any ideas what might have caused this? Please see included meta data and photos. No post processing applied only converted RAW to JPG using Light Room 5.7
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/03/2/LQ_717573.jpg
Image hosted by forum (717573) © sagebrush [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/03/2/LQ_717574.jpg
Image hosted by forum (717574) © sagebrush [SHARE LINK]
MakisM1
Gallery: 50 photos
Joined Dec 2011
Mar 14, 2015 15:46 |  #2
It looks like you are showing two sequential photos, taken at high FPS. The only change in the EXIF is the ISO (were you running AutoISO?). Then, it is likely the current frequency (60 hz).
Gerry
msowsun
"approx 8mm"
Gallery: 18 photos
Post edited over 8 years ago by msowsun. (4 edits in all)
Mar 14, 2015 16:00 |  #3
sagebrush wrote in post #17474939 (external link)
............... A noticeable shift between shots while no change in lighting that could effect exposure or AWB. Does anyone have any ideas what might have caused this? ...............
There is a change in lighting that is not visible to the human eye. Those gymnasium lights are flickering at about 60 (or 120?) cycles per second and that causes variation in both color temperature and light intensity.
If you didn't notice it before you were either very lucky or shooting at a slower shutter speed.
There really is no solution other than shooting a a slower shutting speed or correcting each frame in post processing.
Lupo-Lobo
Gallery: 18 photos
Joined Nov 2013
Post edited over 8 years ago by Lupo-Lobo. (2 edits in all)
Mar 14, 2015 16:09 |  #4
Check your "SHOOT4" settings on the camera and see what your "Anti-Flicker Shoot" setting is. If set to "Disable" then change to "Enable" and try again.
Anti-Flicker, when enabled, seems to control the issue you described pretty well.
Lupo
sagebrush
Joined Dec 2001
Mar 14, 2015 16:10 as a reply to  @ MakisM1's post |  #5
Correct. I shot using AutoISO due to the sudden background change that can occur. And yes the ISO change between frames did change the expose but why the White Balance?
I set the lens wide open and shutter speed to 1/400 to freeze the action (most of the time). So your thinking the 60Hz electric power source to the gym lighting is causing this. Any other ideas out there??
Archibald
You must be quackers!
Gallery: 789 photos
Mar 14, 2015 16:12 |  #6
Use the anti-flicker feature of the 7D2.
bumpintheroad
Self-inflicted bait
Gallery: 21 photos
Joined Oct 2013
Post edited over 8 years ago by bumpintheroad.
Mar 14, 2015 16:12 |  #7
What Mike said. But also, in most school gyms there's a mix of different types of light: high-pressure mercury, halogen, florescent, standard incandescent, even natural daylight from windows. The brightness and color balance can vary at any instant, and even within an individual frame.
The human eye and brain adapts, the eye constantly adjusts without conscious effort, the brain analyzes the individual elements and determines what's white versus red versus yellow and interprets the scene, even different parts of a scene. The camera runs on programming that adjust to an averaged view of the scene, and can't interpret what should be there, it only averages the light and color that falls within its metering pattern. The photographer's job is to turn the camera's "vision" into his own human interpretation.
It appears that the manual settings you're using are good, perhaps I'd dial-in +1/2 to +2/3 stop EC. Then let the camera decide the appropriate ISO and you deal with the color correction in post.
-- Mark | Gear | Flickr (external link) | Picasa (external link) | Youtube (external link) | Facebook (external link) | Image editing is okay
msowsun
"approx 8mm"
Gallery: 18 photos
Mar 14, 2015 16:14 |  #8
Lupo-Lobo wrote in post #17474979 (external link)
Good call! I forgot that the new 7D II has this new Anti-Flicker Mode. More info about it here: http://www.the-digital-picture.com …News-Post.aspx?News=13866 (external link)
sagebrush
Joined Dec 2001
Mar 14, 2015 16:16 as a reply to  @ Archibald's post |  #9
Is there any down side to always keeping anti-flicker enabled for outdoors too?
Archibald
Gallery: 789 photos
Post edited over 8 years ago by Archibald.
Mar 14, 2015 16:23 |  #10
sagebrush wrote in post #17474992 (external link)
I turned my anti-flicker on when the body was new and it has been on ever since. I haven't noticed any problems.
But the camera says it could delay the shutter. Maybe that's why I've been missing those BIF shots! -?
Trvlr323
Mar 14, 2015 16:33 |  #11
Not outdoors but keep in mind what canon reports with the anti-flicker option enabled 'the shutter release lag time may be longer. Also, the continuous shooting speed may become slightly slower, and the shooting interval may become irregular'. I messed around with the anti-flicker a little and did experience the irregular shooting interval mentioned. Ultimately I decided to keep it disabled because I'd rather deal with a little extra PP than having the camera act irregularly at a critical time.
Sometimes not taking a photograph can be as problematic as taking one. - Alex Webb
Archibald
Gallery: 789 photos
Mar 14, 2015 16:49 |  #12
nqjudo wrote in post #17475013 (external link)
Well, at slower shutter speeds, you can get varying white balance in a picture, which is not easy to fix.
sagebrush
Joined Dec 2001
Mar 14, 2015 17:00 as a reply to  @ Archibald's post |  #13
Thanks to all for your welcomed feedback.
I shoot wildlife and BIF just about all the time so will keep Anti-flicker off until the next opportunity I have for Indoor Sports.
MakisM1
Gallery: 50 photos
Joined Dec 2011
Mar 14, 2015 17:08 as a reply to  @ sagebrush's post |  #14
The way I read it, the Anti-flicker kicks in only if flicker is detected. If it kicks in, you need it. If you don't need it, it will not kick in.
In addition, the 'cycle' is 1/100th or 1/120th of a second. The camera will delay a shot by a fraction of that fraction of a second. At the most half, means 1/200th delay. I don't think that there is a man alive that has reflexes that fast (including Mr. Hamilton flying low in Oz!... :-D) I don't think delay will be an issue, it may offset the timing of a high FPS series, but so what?
Gerry
Trvlr323
Mar 14, 2015 18:09 |  #15
Archibald wrote in post #17475032 (external link)
With all the know how and tech around that enables is to fix issues of varying WB, different light sources, etc. it is indeed very easy to fix. A lot easier that re-creating a missed shot anyway.
2,869 views & 0 likes for this thread, 9 members have posted to it and it is followed by 4 members.
1210 guests, 131 members online
