Thread started 15 Mar 2015 (Sunday) 03:23
Tamron 24-70 vc + 5diii users ?
amish
Joined Sep 2013
Mar 15, 2015 03:23 |  #1
Anyone get missed focus shots when using outer AF points?
I recently purchased this lens used from a group on facebook, received the lens and excitedly mounted to my 5diii. The first image a took using one of the upper right AF points (x type), and it was completely soft. In my confusion, I began taking more test shots and discovered that the lens would severely back focus if I attempted to use any of the outer AF points but was tack sharp only in the very center. Seeing how I rarely take a shot using the center AF point, I attempted to MFA the issue away. I was at -20 and was still missing focus. I then called Tamron and found out the lens needed to be adjusted at the tune of $250 minimum. I went to our local camera store (2.5hr drive) and tested their display copy of the lens on my 5diii to find the it to function the exact same way. The store salesman and I mounted the store copy on their 5diii and again had the same results. I then tested the new Canon 24-70 ii on my body and obtained tack sharp photos from every AF point I tried.
here is an image with the upper right AF point in use. subject was the SB700 flash diffuser package text. you can clearly see the severe back focus
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/03/3/LQ_717647.jpg
Image hosted by forum (717647) © amish [SHARE LINK]
amish
Joined Sep 2013
Mar 15, 2015 03:25 |  #2
Here is one with the center point used on the same packaging
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/03/3/LQ_717648.jpg
Image hosted by forum (717648) © amish [SHARE LINK]
DoughnutPhoto
Joined Aug 2014
Mar 15, 2015 05:36 |  #3
My first thought is that maybe this is the reason the lens was sold. If it were under warrantee, I'd just send it in to Tamron as they claim to know the problem and how to repair it.
You could try and focus in Live view, that will most likely give better results. I am thinking that the field curvature of the lens is quite high so that the field of sharp focus is behind where the camera thinks it is for the outer AF points but in the center it's accurate.
You could try and focus on a flat subject using the outer AF points and see if the photo is sharp anywhere.
Canon 5d, 60d, 17-40mm L, 30mm Art, 50mm, 85mm
DoughnutPhoto
Joined Aug 2014
Mar 15, 2015 05:39 |  #4
https://photography-on-the.net …/showthread.php​?t=1274691
From this forum, back in 2013. It appears it's a common issue with the lens. Maybe your copy is from 2013?
If it's common, was there maybe a recall?
amish
Joined Sep 2013
Mar 16, 2015 05:32 |  #5
When I called Tamron on the issue, they were not going to repair free of charge. So I don't think there is a recall
ilikeglass
Mar 28, 2015 00:14 |  #6
The warranty in the US is 6 years - http://www.tamron-usa.com/lenses/warrant​y.php (external link)
That's why grey market Tamron 24-70 go for $900 and from authorized reseller $1,300 (last time I checked).
5D II and 5D III
50mm f1.8 Mk I~85 f1.8~17-40L~Canon 70-200L~430 exII
LV ­ Moose
Moose gets blamed for everything.
Gallery: 223 photos
Mar 29, 2015 09:38 |  #7
I just put this lens through its paces during a recent trip to Valley of Fire State Park (NV), and then a senior shoot. I used a lot of different AF points with my 5DIII and didn't really notice any images being badly OoF. BUT it hunted quite a bit, even in good light. Very irritating, especially when shooting people. Overall though, happy with the sharpness.
Moose
Gear... Flickr (external link)...Flickr 2 (external link)...
Macro (external link)...Hummingbirds (external link)
Aircraft (external link)
amish
Joined Sep 2013
Apr 06, 2015 15:55 |  #8
It seems that i forgot to update this thread with the fact that i went back to Robert's camera in downtown Indy and had them grab a new out of the box lens for me and it worked nearly perfect on my 5diii. I have no idea what the issue was with the other copies. Im assuming a firmware update. Just happy that i found one that works... Also bought the Tamron 15-30 vc. Loving them both
Talley
Talley Whacker
Gallery: 46 photos
Joined Dec 2011
Apr 06, 2015 18:28 |  #9
amish wrote in post #17506894 (external link)
ugh... my 15-30 is backordered... wth... i want one now
A7rIII | A7III | 12-24 F4 | 16-35 GM | 28-75 2.8 | 100-400 GM | 12mm 2.8 Fisheye | 35mm 2.8 | 85mm 1.8 | 35A | 85A | 200mm L F2 IS | MC-11
My Gear Archive
amish
Joined Sep 2013
Apr 07, 2015 06:18 as a reply to  @ Talley's post |  #10
Yeah it was a total fluke that I ended up with one Talley. I had to drive back 2hrs to return a defective Tokina 16-28 that I had purchased 2 earlier and the sales guy pulled this one from the back. Said they had just got it in that day+. I already knew I was going to buy it before I mounted it to my body for test shots.
Talley
Talley Whacker
Gallery: 46 photos
Joined Dec 2011
Apr 07, 2015 08:33 |  #11
amish wrote in post #17507640 (external link)
U suck  :p
My Gear Archive
Patbil10
Gallery: 57 photos
Joined Apr 2014
Apr 07, 2015 08:49 |  #12
I returned my copy of this lens for lack of sharpness (perhaps due to bad focusing) and purchased the Canon version. Best decision ever as my keeper rate is almost 100%.
Canon 5D Mark IV, Canon EOS M5, Canon EF 24-70mm f/2.8L II,Canon EF 70-200mm f/2.8L IS II,Canon EF 100mm f/2.8 macro, Sigma 35mm Art, Tamron SP 85mm f/1.8, EF-M 22mm f/2, Canon ef-m 15-45, Rokinon 14mm f2.8 and other stuff...
amish
Joined Sep 2013
Apr 07, 2015 09:20 |  #13
Talley wrote in post #17507734 (external link)
U suck  :p
Sorry Talley... wasnt trying to rub it in..... ok maybe a little:lol:
amish
Joined Sep 2013
Apr 07, 2015 09:23 as a reply to  @ Patbil10's post |  #14
I tested the store copy of the Canon mkii... it was amazing and I was ready to pull the trigger before i discovered that there were some good copies of the Tamron. I would have been happy either way. I may end up with the canon at some point.
MBB89
Joined Jan 2015
Apr 07, 2015 12:35 |  #15
How big have the issues with the Tamron AF been overall?
4,157 views & 0 likes for this thread, 7 members have posted to it.
1334 guests, 169 members online
