Thread started 26 Feb 2006 (Sunday) 19:48
Extension tube for G6
mknabster
Feb 26, 2006 19:48 |  #1
Does Canon or anyone else sell any extension tubes ofr the G6? I do have the lens adapter top connect both the wide angle and tele converter lense to the G6, but i was wondering if there was a way to hook up a filter w/ on of the accesory lenses.
- Matt
MK Studios (external link)
Terrywoodenpic
Feb 27, 2006 07:26 |  #2
Look on ebay there are dozens of close up lenses to chose from, that will fit your lens adapter.
You can't fit an extension tube as they are for slr cameras and fit between the body and the lens. to increase the extension, for close up work.
Terry
Terry_______________
Over 60 years in photography
wasted money cameras never on film.
Alnath
Joined Dec 2003
Feb 27, 2006 11:24 as a reply to  @ Terrywoodenpic's post |  #3
Yup got mine off ebay (a hyundai one) for £5, it works a treat.
John
Click to view my photos (external link)
dbump
Joined Apr 2003
Feb 27, 2006 13:27 |  #4
Mknabster,
So you have the Canon lens adapter tube? You can certainly use 58mm filters with that alone, but I don't think any of the Canon conversion lenses have external threads, so in order to use a filter and a lens, you'd need to thread the filter to the adapter tube, and then the conversion lens to the filter. Because this pushes the lens further from the camera, you may encounter vignetting (or more vignetting). If you want to use a polarizer, be very careful, as they are not designed to hold weight across the rotating joint, and it's possible for your heavy lens to separate the filter halves and fall off.
Some non-Canon conversion lenses that work with the G do have external threads. The only downside is that you'd need a larger diameter filter to work with the lens, and a normal 58mm to work with just the adapter tube and no conversion lens.
Have you been to www.lensmateonline.com​? (external link) Very well reviewed here. I have one of their adapter tubes, and love it. If you already have one, not as useful, but they have some info on non-canon lenses.
7D, G10, 17-55 f/2.8 IS, 70-200 f/2.8 IS, 100 Macro, 50 f/1.4, 430EX II
There are no wrong notes
--Thelonious Monk
mknabster
Feb 27, 2006 14:44 as a reply to  @ dbump's post |  #5
Yea, that's what i meant dbump, about fitting a fliter onto one of the accesory lenses or vice versa. I won't try it if it will damage either the lense or filter, i know both are fragile. Thanks for clearing that up though!
- Matt
dbump
Joined Apr 2003
Feb 27, 2006 15:14 |  #6
The only danger that I know of is with polarizers. I've done it, I've just made sure I was always holding the lens with one hand while it was mounted.
No problem, glad to help!
--Thelonious Monk
2,484 views & 0 likes for this thread, 4 members have posted to it.
2149 guests, 127 members online
