Thread started 16 Mar 2015 (Monday) 06:02
DSLR Video... dealing with wind
davebreal
Mar 16, 2015 06:02 |  #1
Anyone have words of wisdom for filming DSLR video in wind, and avoiding the camera shaking from wind drag?
I've been doing wildlife filming lately with my Tamron 150-600mm lens atop a Benro carbon fiber tripod. It takes large gusts of wind to bounce the camera while I'm filming, but it does happen. Is it just a fact of life? Seems like a large lens gathers more wind drag than a smaller setup.
I obviously cut the jostled footage in post, but I'm wondering if there's any other remedy. BTW - I am shooting by myself, so I don't have anyone else to assist.
Dave
flickr  (external link)Twitter  (external link)Wordpress Blog (external link) YouTube (external link)
My Gear--> Facebook (external link)
PhotogNY
Mar 16, 2015 06:39 |  #2
Wow, it's so windy your tripod is shaking?? Did you sandbag the legs?
Long Island Evictions (external link)
davebreal
Mar 16, 2015 08:38 |  #3
PhotogNY wrote in post #17477119 (external link)
Haven't sandbagged the legs, no, but I am moving the tripod outdoors in fields and woodlands between shots to change angles so I need to be fairly mobile. I think the lens itself is part of the cause, it's mostly plastic and has a large lens hood so it catches a great deal of wind.
Dave
RDKirk
Adorama says I'm "packed."
Joined May 2004
Mar 16, 2015 10:40 |  #4
For sure, the lens is the issue. Even if you've perfectly balanced the weight of the camera-cum-lens on the tripod, with a lens that long the image is going to show movement over the moments in video...which is kind of like a very long timed exposure for a still.
Sandbagging the tripod won't help much --the bulk of the lens is catching the wind and will cause some montion visible at the longest focal length because you won't be able to prevent all flex in the head and the connection. You will probably have to give up a lot of mobility to dampen it by a technique such as using two tripods (one at the camera socket, another at the lens' socket and laying a sandbag on the lens between them.
davebreal
Mar 16, 2015 17:57 |  #5
RDKirk wrote in post #17477359 (external link)
Those sound like words of wisdom and experience. Great advise, thanks!
Dave
RDKirk
Joined May 2004
Mar 16, 2015 19:19 |  #6
What might be easier, whenever possible, is using natural support--a tree bough or a rock. Throw a cushion on the rock, lay the lens on it and drop a sandbag over it.
BarrySpug
Joined Oct 2011
Apr 23, 2015 20:09 |  #7
If you have an assistant (or willing friend) you could get them to hold up some sort of wind break right next to the lens / camera so it deflects the gusts and is still out of shot. A medium sized piece of stiff cardboard should suffice and still allows for mobility when you need to move.
Canon 7D gripped | EF-S 18-135mm | EF 50mm 1.8 | EF 70-200mm F2.8 L IS II | Steady hand | Fingers Crossed
2,423 views & 0 likes for this thread, 4 members have posted to it and it is followed by 3 members.
1096 guests, 119 members online
