Something like this?
IMAGE LINK: https://flic.kr/p/r2toPr
Macro selfie (or Solar eclipse in the eye)
by
syamastro
, on Flickr
It is a selfie, with no assistant, so even more difficult to produce. I probably spent an hour trying to get a nice setup. This is macro (1.6:1), using 70-200mm f4 lens at 200mm with a full set of extension tubes with AF wiring. The trick was to have a fairly large light source (visibly much larger that the camera focused on your eye) - 60" octagon softbox in my case, located far enough to have its reflection completely contained within the pupil. Then you place the camera on a tripod between your eye and the softbox. At the end, you see a large (but smaller than the pupil) softbox reflection with a small silhouette of the camera in the middle. (It helps to have the room fairly dark, so your pupil gets large.) This can be easily removed in PP as it's entirely in the black (pupil) area.
The hardest part for such a selfie is to get the focus right. AF only works when you are withing a fraction of a mm of the sharp position, and then it will focus on the camera reflection, which throughs iris out of focus. I ended up playing with MFA numbers (using Magic Lantern, which allowed me to go way beyond the Canon's -20...20 range for MFA) until it was the iris which was in focus when AF was engaged. Overall, ~100 flashes at full power from YN560 right into my eye to get it right
