Thread started 27 Mar 2015 (Friday) 13:59
Need a new flash
samueli
Gallery: 11 photos
Mar 27, 2015 13:59 |  #1
Hello,
I'm currently running with a canon 5d3, and had a 580x type flash , along with 2 useless 430 models that I used on camera and with umbrellas, with Paul C. Bluff triggers.
Doing some after wedding outdoor shoots this winter, I slipped on ice, and when I hit the ground, the shock broke the attachment section of the 580, so I can no longer attach it to anything. So now I am out my one good flash, and I'm not sure what to replace it with.
Also, regarding the Paul C. Bluff triggers; they are great for practice, but aren't reliable when actually doing work. I find that I need to disconnect and reattach everything every few shots to keep everything working. It gets embarrasing after awhile to say the least.
So obviously I need a new flash or two, and I'm wondering what is a good bet these days that may or may not compliment my 5d3? I've never been able to use a TTL option, so I do everything manually with a bit of chimp to get set up.
Any recommendations? Will my unreliable triggers get better with an up-to-date flash? I pretty much had one good flash setup, and two more without umbrellas for emergency. I'd like to have two or three full, reliable off-camera flashes with umbrellas going forward.
Thank you!
GeeMack
Gallery: 10 photos
Mar 27, 2015 17:12 |  #2
I'd go with a couple of these flashes: http://www.amazon.com …keywords=yongnu​o+600ex-rt (external link)
And get this to get them off camera: http://www.amazon.com …keywords=yongnu​o+600ex-rt (external link)
7D, 50 f1.8, 17-55 f2.8, 70-200 f2.8 II, 100-400 f4.5-5.6L, 2x TC III, 580EX II, 430EX, 568EX II, 622C
glmphotos.zenfolio.com (external link)
flowrider
Gallery: 127 photos
Mar 27, 2015 17:16 |  #3
Cheetah V850 with LiOn built in batteries.
~Steve~
~ My Website-stevelowephoto.com (external link) ~ Facebook (external link)
Feedback Feedback Feedback
Wilt
Mar 27, 2015 17:29 |  #4
The plastic hotfoot of the 580 can be replaced!
inkista
Mar 27, 2015 17:49 |  #5
samueli wrote in post #17494418 (external link)
... the shock broke the attachment section of the 580, so I can no longer attach it to anything.
This is easily fixed/replaced. It's a DIY thing--get the part, and replace it yourself. If you don't mind spending up to $50, you could even get an entire foot assembly and replace it and have a 3.5mm sync port (external link) on the flash. :)
I mean, if you want to buy a new flash, you can buy a new flash. But you could just repair this one.
... I've never been able to use a TTL option, so I do everything manually with a bit of chimp to get set up.
But do you want TTL/HSS/remote power control?
What's your budget?
And are you sure you want to stick with speedlites? Or do you want bigger, more powerful lights? (AlienBees, Godox Wistros, etc.)
I'm a woman. I shoot with a Fuji X100T, Panasonic GX-7, Canon 5DmkII, and 50D. flickr stream (external link)
Phil ­ V
Joined Jan 2005
Mar 27, 2015 18:13 |  #6
inkista wrote in post #17494659 (external link)
What's your budget?
All of this^
website: South Yorkshire Wedding photographer in Doncaster (external link)
Twitter (external link)Facebook (external link)
samueli
Gallery: 11 photos
Mar 27, 2015 18:48 |  #7
GeeMack wrote in post #17494630 (external link)
these look neat!
samueli
Gallery: 11 photos
Post edited over 8 years ago by samueli.
Mar 27, 2015 18:52 |  #8
I didn't think that could be replaced. I didn't really look that hard at it though.
I mean, if you want to buy a new flash, you can buy a new flash. But you could just repair this one.But do you want TTL/HSS/remote power control? What's your budget? And are you sure you want to stick with speedlites? Or do you want bigger, more powerful lights? (AlienBees, Godox Wistros, etc.)
I wouldn't mind some better flash equipment. Everything I purchased was on a beginner budget. The 580 could be 2nd or 3rd flash. I have 2 430ex that shut off after 30 seconds. I could bump those out.
Indeed more power, but being mobile is important. I could spend on some lighting as long the equipment stays relevant.
windpig
Chopped liver
Mar 27, 2015 21:46 |  #9
flowrider wrote in post #17494633 (external link)
This
Go ahead, spin the wheel.
samueli
Gallery: 11 photos
Mar 27, 2015 23:32 |  #10
Cheetah and Godox are the same? These look pretty sweet!
FJ ­ LOVE
Mar 28, 2015 00:17 |  #11
samueli wrote in post #17494961 (external link)
i have this setup, and the transmitter works flawlessly for off camera and the adjustments are easily made from the hotshoe with a readout of the power output, ideal for chimping
DILLIGAF about your bicycle or your gear
bumpintheroad
Self-inflicted bait
Gallery: 21 photos
Joined Oct 2013
Mar 28, 2015 01:34 |  #12
If you're not using ETTL you can get YN-560 III or IV with built-in RF receivers and a YN-560-TX RF trigger that will allow you to configure the flash settings remotely. You can get two flashes plus the trigger for under $200, and they are widely available on Amazon and eBay. Want faster recycling time or longer battery duration: get a pair of CP-E4 battery pack clones for another $60.
-- Mark | Gear | Flickr (external link) | Picasa (external link) | Youtube (external link) | Facebook (external link) | Image editing is okay
OceanRipple*
Joined Dec 2014
Mar 28, 2015 04:35 |  #13
For your useless 430Exs, it might be an idea to check out CFn-01.
samueli
Gallery: 11 photos
Post edited over 8 years ago by samueli. (2 edits in all)
Mar 28, 2015 09:22 |  #14
One reason I'm not using ETTL is because I could not. In the end, I probably don't need it since I've been fine without it and don't know if I'm missing anything. Hmm... So now it's back to nice equipment or cheaper equipment. There is a reason I kept away from these boards, lol.
The Cheetah/Godox are presented so very nicely. What about the Lithium batteries? Is that way better than 5lbs of double As? In all my camera stuff, with aftermarket replacement batteries, I have around a 25% fail rate on rechargables. Decisions, decisions...
Wow, the Yongnuo equipment looks pretty sweet as well, and I can get twice as much equipment for the price.
Thanks for all the responses!
samueli
Gallery: 11 photos
Mar 28, 2015 09:27 as a reply to  @ OceanRipple*'s post |  #15
Does that work for the 430? I remember getting a schematic from Canon that required board modifications. I eventually decided against breaking out the soldering iron.
8,840 views & 2 likes for this thread, 13 members have posted to it and it is followed by 8 members.
Need a new flash
644 guests, 120 members online
