Thread started 28 Mar 2015 (Saturday) 06:35
Baseball with New 6d
connor8100
Mar 28, 2015 06:35 |  #1
Bought a 6d for xmas and have been pretty happy with it. Noticed the first time I took it outside, for Baseball (been cold and wet here) that it seemed to underexpose slightly, bumped the compensation up by 2/3 which corrected that but every so often in auto iso it will drop a pic to 100 iso making those captures unusable.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/03/4/LQ_720027.jpg
Image hosted by forum (720027) © connor8100 [SHARE LINK]
Gary ­ Wiant
Joined Sep 2009
Mar 28, 2015 07:52 |  #2
Can I ask why you are using auto ISO? What mode are you shooting in?
Gary Wiant
R6 Mark II - Eos- M - RF 28-70 F2.0 - RF 70-200 F2.8 - RF50 f1.8 - EF 17-40 F4 - EF100 2.8 Macro - EF EOS RF Afaptor - M22mm - M18-55 - Canon Ef-Ef-s to M converter - 1.4x VIII & 2x VII extenders - 540EXII Flash, Flash Zebra SF-18 Ext. Battery Pack, Kenko Extension Tubes - Manfroto Macro Bracket - Lensalign Flickr (external link)
connor8100
Mar 28, 2015 13:17 as a reply to  @ Gary Wiant's post |  #3
Auto iso for convenience, shooting in shutter priority between 1/1600 and 1/2000. First time with the camera outside and the first time with the 100-400 on it. Moved up from a T1 to the 6d.
Gary ­ Wiant
Joined Sep 2009
Post edited over 8 years ago by Gary Wiant.
Mar 28, 2015 14:54 |  #4
I'm no pro by any means but what I do is shoot aperture priority set my aperture to the dof that I'm after usually lowest I can get with the lens then adjust my iso to get the desired shutter speed then fire away. You can get great shots with a much higher iso on the 6th than you could with the T1i. I mainly shoot night football and I can comfortably shoot iso4000 with the 1D3 and now I have the 1D4
Gary Wiant
connor8100
Mar 28, 2015 15:21 as a reply to  @ Gary Wiant's post |  #5
Definitely give that a try, thanks for the feedback and a great tip!
carpenter
Gallery: 12 photos
Mar 30, 2015 14:50 as a reply to  @ Gary Wiant's post |  #6
I see no issue with auto ISO. Set your desired shutter and aperture and as clouds roll in or out or day gives way to early evening you are good to go with no changes.
5D Mk IV | 24-105L | 85 1.8 | 70-200L 2.8 IS MkII | 100-400L MkII
Gary ­ Wiant
Joined Sep 2009
Mar 30, 2015 17:57 |  #7
But I'd you're shooting full manual you'll miss more shots than shooting AV with a set ISO. If your shooting full manual you really need to be paying attention to the exposure every shot instead of consintrating on following the action
Gary Wiant
McNeese72
Gallery: 1023 photos
Mar 30, 2015 19:32 |  #8
Gary Wiant wrote in post #17498522 (external link)
Shooting manual with auto-ISO works for me with the 7DII. Especially, shooting outside sports like a baseball game on a partly cloudy day where the sunshine is intermittent with clouds. You can set the shutter speed and aperture where you want them and forget about it and shoot away.
And with the 7DII you have the option of exposure compensation when shooting manual with auto-ISO.
Doc
2 Canon 1Dx's | Canon R6 | EF 70-200 F2.8 L IS II | Canon 300mm F2.8 I | EF 24-70mm f/2.8L II USM | Canon Extender EF 2x III | Canon Extender EF 1.4x III | Editing of photos is okay.
Doc's Shots (external link) USMMcNeese72 Flickr Page (external link)
connor8100
Apr 04, 2015 05:46 as a reply to  @ McNeese72's post |  #9
Tried manual auto iso combo, worked really good until this anomaly popped up. Following pictures were back to back series (last /first) only difference in exif was 20mm in focal length, first was 310 second was 330. ISO dropped from 1000 to 200. Not being able to adjust exposure compensation in camera made more post work. I sincerely appreciate everyones comment's and suggestions. Not sure if this is a lens or camera issue at this point, will try the same settings with another combination and see what I get. Pics are SOOC, Thanks , Chris
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/04/1/LQ_721141.jpg
Image hosted by forum (721141) © connor8100 [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/04/1/LQ_721142.jpg
Image hosted by forum (721142) © connor8100 [SHARE LINK]
Gary ­ Wiant
Joined Sep 2009
Apr 04, 2015 06:10 |  #10
Have you tried my way of shooting with set ISO and AV mode yet?
Gary Wiant
Left ­ Handed ­ Brisket
Gallery: 15 photos
Joined Jun 2011
Post edited over 8 years ago by Left Handed Brisket.
Apr 04, 2015 06:40 |  #11
it's probably your metering mode, especially considering you are shooting guys with black jerseys. If the camera weights the jersey heavily you get an over exposed shot, if it weights it lightly you get a under exposed shot.
what mode are you in, and how/when are you activating AE?
edit: FWIW, i would be shooting full manual in those conditions. If there were some big fluffy clouds moving across the sky changing the light every minute or two, i would be in Av with an ISO setting that kept SS high. Being new to the 6D you might not be comfortable with high ISO yet, just go for it.
connor8100
Apr 05, 2015 09:18 as a reply to  @ Left Handed Brisket's post |  #12
Gary, to answer your question, not yet. Have a game tomorrow , will try it then, and post the results. As for exposure, have been using partial metering , AI Servo, and center point focus. Theses were shot at 1/3200, f4.5 to 5.6 depending on focal length. Couple from the last outing. Have a safe holiday. Thanks, Chris
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/04/1/LQ_721295.jpg
Image hosted by forum (721295) © connor8100 [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/04/1/LQ_721296.jpg
Image hosted by forum (721296) © connor8100 [SHARE LINK]
Gary ­ Wiant
Joined Sep 2009
Apr 05, 2015 12:05 |  #13
Sounds good, Try some also with spot metering. I shoot sport exclusively with spot metering, but like I said I'm no pro so I may be wrong but I know my keeper rate is pretty high.
Have a great Easter
Gary Wiant
cstewart
Apr 05, 2015 12:58 |  #14
carpenter wrote in post #17498281 (external link)
Agreed. I used to shoot baseball with Av priority (f4.0) and had to keep adjusting ISO to get shutter speeds preferred (usually 2500 and higher to freeze arm motion, bat speed and ball). Now shoot mostly in Manual, f4.0, 1/3200 and Auto ISO with +1/3 to 2/3 EV which I can do on 1DX. The main reason for this is that our diamonds get home plate in shadow pretty early in evening while second base is still in nice sunlight....makes it easy when quickly shooting one area and then the next to not to have to switch settings.
Some will worry about noise and such at higher ISO settings when they happen but for me with the 1DX and 1D Mk IV (my main two sports bodies) this is not an issue.
Please Check Out My Work at:
Independent Sports News (external link) -- Sports Shooter (external link) --Web Site (external link) -- Facebook (external link) -- iStockphoto.com (external link)--Twitter (external link)
Gear: 1DX; 1D4; 70D gripped; 40D gripped; ; EFS10-22; EFS 17-55; EF 16-35; EF 135; EF 70-200 II; EF 300; EF 1.4X II Extender, 580 EX II Flash
Gallery: 15 photos
Joined Jun 2011
Apr 05, 2015 14:30 |  #15
http://www.digitalcame​raworld.com …ork-and-when-to-use-them/ (external link)
Decent, quick explanation of canon metering modes^
Evaluative might be your best bet.
6,035 views & 0 likes for this thread, 8 members have posted to it and it is followed by 3 members.
622 guests, 116 members online
