Thread started 28 Mar 2015 (Saturday) 22:55
Trying to upgrade please help
LynneVictor
Gallery: 69 photos
Joined Aug 2013
Mar 28, 2015 22:55 |  #1
I currently own a 40D and a 60D, I am thinking about purchasing a 6D but am I correct that all my Canon EFS lenses won't work on the 6D? I also have two Tamron lenses SP-AF-DI 200-500 and a 28-300 aspherical XR DI, would those work on a 6D? I want to upgrade but don't want to have to replace six lenses. Suggestions please.
Canon 70D, 6D Mark ll, Canon 55-250mm, Canon 18-135mm, Tamron 28-300mm, Tamrom 150-600mm and Canon 20mm f2.8
crbinson
Joined Jul 2012
Post edited over 8 years ago by crbinson.
Mar 28, 2015 23:08 |  #2
Canon EF-S lenses will not be compatible with the 6D EF mount. Not sure about your Tamron lenses.
My Flickr (external link) | My Gear List
LynneVictor
Gallery: 69 photos
Joined Aug 2013
Mar 28, 2015 23:16 |  #3
The Tamron lenses have a red dot. So that is the key, a red dot works with the full frame camera the white dot doesn't?
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Mar 28, 2015 23:20 |  #4
If a 3rd party lens was made to work with EF-S, it will mount, but you will still have an EF-S lens, ie: the image circle from the lens will be too small for your larger FF sensor.
CDS' HOT LINKS
LynneVictor
Gallery: 69 photos
Joined Aug 2013
Mar 28, 2015 23:26 |  #5
So basically I would have to buy all new lenses if I bought the 6D? Is there any other camera that is an upgrade from what I have that has wi-fi that I could use with my current lenses?
Charlie
Guess What! I'm Pregnant!
Mar 29, 2015 00:15 as a reply to  @ LynneVictor's post |  #6
Without googling, 90% sure that both tamrons are FF lenses.
Sony A7siii/A7iv/ZV-1 - FE 24/1.4 - SY 24/2.8 - FE 35/2.8 - FE 50/1.8 - FE 85/1.8 - F 600/5.6 - CZ 100-300 - Tamron 17-28/2.8 - 28-75/2.8 - 28-200 RXD
Panasonic GH6 - Laowa 7.5/2 - PL 15/1.7 - P 42.5/1.8 - OM 75/1.8 - PL 10-25/1.7 - P 12-32 - P 14-140
GeoKras1989
Joined Jun 2014
Mar 29, 2015 02:17 |  #7
Tamron designates FF lenses as: Di.
Lenses designed for APSC are: Di II.
Di II lenses will mount and function on full frame cameras. You will get a round image surrounded by blackness with them on FF bodies. My 17-50 Di II worked just fine on my 5Dc. However, the results really sucked.
WARNING: I often dispense advice in fields I know little about!
lellololes
Joined Feb 2015
Mar 29, 2015 02:45 |  #8
If you want wifi on a crop body, I believe the 70D is your choice.
LynneVictor
Gallery: 69 photos
Joined Aug 2013
Mar 29, 2015 14:30 |  #9
Is the full frame body that much better than what I currently own for me to buy a new camera and lenses?
bumpintheroad
Self-inflicted bait
Gallery: 21 photos
Joined Oct 2013
Post edited over 8 years ago by bumpintheroad. (2 edits in all)
Mar 29, 2015 14:45 |  #10
It depends on what you're shooting.
But your question does suggest that, at this time, full-frame might not make a big enough difference to you to warrant changing everything up.
-- Mark | Gear | Flickr (external link) | Picasa (external link) | Youtube (external link) | Facebook (external link) | Image editing is okay
lellololes
Joined Feb 2015
Mar 29, 2015 15:09 |  #11
In typical situations, there's not an enormous difference between them.
The biggest differences will be found in -
Low light/High ISO performance is significantly better on FF bodies.
Per pixel detail is better if the megapixel count is similar - a 20MP FF image vs a 20MP crop camera image with similar quality lenses will show an advantage to the FF image.
Larger sensor size necessitates longer focal lengths to acheive the same viewing angle. AKA you have less reach with a telephoto lens, and you have less depth of field on the FF camera. To make things roughly equivalent, multiply the aperture on the crop camera by the crop factor for what it would look similar to.
For example:
135mm f/2 on crop
135 x 1.6 = 216mm
2 * 1.6 = f/3.2
So a 135mm f/2 lens will give similar results to a 216mm f/3.2 lens on a FF camera.
500mm f/6.3 on crop ~= 800mm f/10 on full frame
500 x 1.6 = 800
6.3 * 1.6 = 10
The full frame camera will need to use a higher ISO to acheive the same shutter speed - and this also factors in to equivalency. The FF body will need to use a higher ISO, but it will result in fairly similar image quality.
If you're looking at faster glass, here's one in reverse:
50mm f/1.2 on full frame
50 * (1/1.6) = 31mm
1.2 * (1/1.6) = f/0.75
So a 50mm 1.2 on a FF camera would be like a 31mm f/0.75 on a crop camera.
FF is less important if:
Crop cameras offer enough image quality for what you're doing
You're limited by focal length. If you're limited by focal length you will need a much larger lens to get similar results from the full frame camera
You need a faster camera: right now there's no inexpensive Canon FF body with great AF/frame rate performance
FF may be a good choice if:
You're not focal length limited by what you're doing
You desire the ability to print larger or use higher ISOs
You desire the ability to control depth of field even more
LynneVictor
Gallery: 69 photos
Joined Aug 2013
Mar 29, 2015 17:59 |  #12
I mainly shoot landscape and nature photography. I wouldn't mind spending the money on a new camera and lenses if the end results justified it.
MalVeauX
"Looks rough and well used"
Gallery: 2135 photos
Joined Feb 2013
Mar 29, 2015 18:06 |  #13
LynneVictor wrote in post #17497137 (external link)
Heya,
Eh, unless you're doing huge prints and unless you need an extra stop of low ISO shadow push, you're not going to get a huge difference in landscape from a 6D compared to a 60D with good glass. Most of it is in the technique and processing. If you look at a lot of the stunning landscape work in the best of' galleries, you'll note a lot of APS-C's in there that you'd never expect.
I'd get the 6D if you wanted the ISO performance at the high side of things.
I'd prize a good piece of glass and filters over a camera, personally.
Can you post some of your work that you think would be significantly improved had you shot it with a full frame?
Very best,
LynneVictor
Gallery: 69 photos
Joined Aug 2013
Mar 29, 2015 18:59 |  #14
Here are some samples of what I usually shoot.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/03/5/LQ_720334.jpg
Image hosted by forum (720334) © LynneVictor [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/03/5/LQ_720335.jpg
Image hosted by forum (720335) © LynneVictor [SHARE LINK]
LynneVictor
Gallery: 69 photos
Joined Aug 2013
Mar 29, 2015 19:00 |  #15
A few more.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/03/5/LQ_720336.jpg
Image hosted by forum (720336) © LynneVictor [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/03/5/LQ_720337.jpg
Image hosted by forum (720337) © LynneVictor [SHARE LINK]
4,244 views & 0 likes for this thread, 8 members have posted to it and it is followed by 3 members.
1304 guests, 125 members online
