FORUMS General Gear Talk Camera Bags, Backpacks & Cases
Thread started 30 Mar 2015 (Monday) 21:39
Suggestion for shoulder strap (x strap) or spider holster
aznkid248
Joined Sep 2012
Post edited over 8 years ago by aznkid248.
Mar 30, 2015 21:39 |  #1
I am wondering what would be a better strap when taking it out to festivals or out on wild life with my 5D Mark 3? I have been using the factory canon strap, but I am not sure what would be a better solution when taking pictures and more convenient to carry around along with my gear.
Update: Should I use a spider holster? I want to keep my gear to be safe away being robbed?
Scatterbrained
Gallery: 267 photos
Best ofs: 12
Mar 30, 2015 22:05 |  #2
Luma Cinch (external link)
500px (external link)
1x (external link)
instagram (external link)
SYS
Gallery: 602 photos
Joined Jul 2004
Mar 30, 2015 22:38 |  #3
Cotton Carrier Vest by itself or with a Think Tank Speed Pro Belt (or Steroid Belt).
-Goethe
Iscariotau
Gallery: 53 photos
Joined Jun 2011
Mar 30, 2015 22:46 |  #4
Not sure if its what you are asking for but I use a Sun sniper strap which is similar to the black rapid.
MyFlickr (external link)
Echo63
Mar 30, 2015 23:22 |  #5
I love my Spiderholster - one of the best bits of gear i have bought.
The blackrapid straps are good too - but the weight is still on your shoulder and it gets tangled in your backpack straps.
My Best Imageswww.echo63.deviantart.​com (external link)
Gear listhttps://photography-on-the.net …p?p=2463426&pos​tcount=385
aznkid248
Joined Sep 2012
Mar 31, 2015 01:16 as a reply to  @ Iscariotau's post |  #6
I'm just asking what is a good strap. Or is it better to use a spider holster?
ian_socool
Gallery: 39 photos
Joined Dec 2011
Aug 29, 2015 14:35 |  #7
My brand!
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/08/5/LQ_744944.jpg
Image hosted by forum (744944) © ian_socool [SHARE LINK]
70D, 80D, SL1, Sigma 10-20 3.5, Σ30mm 1.4, 40mm 2.8 Pancake Σ70mm 2.8 EX DG Macro, Canon 17-55 2.8 IS, Σ85 1.4, Σ50-150mm f/2.8 EX DC OS HSM APO, Godox AD 200 X's 2, 430EX II X's 2, Yongnuo YN-560II X's 2, Cowboy Studio wireless flash triggers X4.Ian_socool FlickR (external link) Facebook fanpage (external link) http://ianlynphotograp​hy.com (external link)
BossBob
Aug 30, 2015 02:42 |  #8
I'm trying out a CapturePro from Peak Design along with a ProPad as an alternative to the Blackrapid setup that I've been using for a while. I got fed up with the extra strap along with a backpack and the CapturePro seems to solve that. Seems pretty secure and has a system that gives a two stage release so the camera/lens needs 3 things to happen before its on the floor.
eelnoraa
Aug 31, 2015 13:35 |  #9
I was going to give Peak design strap a try. After receiving from Amazon, I just feel the "anchor" thingy feels just too weak. I really don't have confident on the tiny so called Kavlar string. Then I did some research on Peak design and found at least one user with anchor string failing and damaging cameras. The strap is return to Amazon at this point.
Also, I found there are a few failure report about the receptor size of the anchor failing. Not sure if PD has fixed this. Overall, my confident isn't high at this point.
5Di, 5Diii, 28, 50, 85, 16-35II, 24-105, 70-200F2.8 IS
BossBob
Aug 31, 2015 15:00 as a reply to  @ eelnoraa's post |  #10
The CapturePro attached to a belt or backpack strap doesn't involve an anchor link unless you want to add another strap of some kind. I'm trying to reduce straps so I'd only add a clutch or maybe some kind of backup strap.
I've had an op tech wrist strap which uses a string similar to the anchor link string for many years, used on a canon G3 and then when I've wanted to carry 2 dslr's. It shows no sign of wear.
2,365 views & 1 like for this thread, 8 members have posted to it and it is followed by 5 members.
1501 guests, 134 members online
