FORUMS General Gear Talk Data Storage, Memory Cards & Backup
Thread started 01 Apr 2015 (Wednesday) 15:37
Help! Win 7 telling me I need to format external drive before using that has been in use for years
mr2step
Apr 01, 2015 15:37 |  #1
I've got an older WD external drive that is externally powered via power cord. Recently, I began to notice a pop up on my screen telling me I needed to format drive M before using it. It popped up over and over and would boot up Lightroom as a result. I disconnected all my USB hookups to try and find the culprit. It seems that this particular drive is it. When I plug it in I hear the familiar " bug duh" that recognizes the connection however, it is not showing up in "my computer" and I cannot get it to recognize. Does anyone know how I can fix this or anything I can try to do as I am at wits end. It just started randomly and was working fine a few days ago. Thanks!
Do what you love, and you will never work a day in your life.
www.Brettmissick.com (external link)
http://www.facebook.co​m/brettmissickphotogra​phy (external link)
Trvlr323
Apr 01, 2015 15:54 |  #2
It might be a software bug somewhere but most of these external units start to fail electronically one way or another before the drive goes bad. You could try it on a different computer or try swapping the cables. To see whether or not it is the enclosure or the drive the definitive test would be to connect the drive to a computer after removing it from the enclosure. If it is the disk itself that i starting to go data recovery software might get your data back if it isn't too far gone. In the meantime I would avoid accessing it unnecessarily or doing any kind or read or write attempts outside of recovery.
Sometimes not taking a photograph can be as problematic as taking one. - Alex Webb
seall
Gallery: 14 photos
Joined Mar 2012
Post edited over 8 years ago by seall. (2 edits in all)
Apr 01, 2015 16:06 |  #3
If you want to check or tey to recover your data "read only" you could try the deft toolkit.
http://www.deftlinux.n​et/about/ (external link)
I use it for critical situations, it works very well indeed.
110yd
Joined Jan 2005
Apr 01, 2015 21:08 |  #4
Just a guess, but I suspect the USB interface of your external drive is going bad. That is not a death sentence. It just means that you may have to open the case, and remove the drive so you can use the HD with another adapter or interface. I have seen more than my share of external USB drives fail in this manner.
I have a USB to IDE/Sata interface that I use in this situation.
Hope this helps,
110yd
Wilt
Post edited over 8 years ago by Wilt.
Apr 01, 2015 21:43 |  #5
I agree that the supporting electronics of the external harddrive could be at fault...open up the enclosure and remove the harddrive itself, insert it into a docking unit...you could find everything is fine.
I had a WD Mybook that failed, I broke into the enclosure (I had to hacksaw the frame apart to get the HD out!), put the HD into a docking unit, and had access to all of my data.
1,273 views & 0 likes for this thread, 5 members have posted to it and it is followed by 2 members.
1507 guests, 130 members online
