Thread started 01 Apr 2015 (Wednesday) 16:02
EOS 10D Error
4N2RR
Joined Apr 2015
Apr 01, 2015 16:02 |  #1
I bought this camera used and the problem didn't start happening until the starting venturing into Manual and TV Mode.
Like for example i was trying to take a picture of some trees and when i looked to see the picture the camera had ERR 99 on it and it didn't sound like the shutter opened and closed all the way.
And today i got some ND filters and was trying to take a picture of the sky to get some blurry clouds and i put it on a 30 second shutter because i was using a 4 stop and around 10 seconds in the shutter went back down and i got ERR 99 again. and i was using f27 to try and get a full picture i even tried to lower it a bit to see if that helped and it didn't and i was using an iso of 100.
Does anyone know whats causing this?
Copper ­ NYC
Joined Sep 2011
Post edited over 8 years ago by Copper NYC.
Apr 01, 2015 19:32 |  #2
4N2RR wrote in post #17500972 (external link)
your guess is as good as mine. Sorry to say but if its the main board, its time to upgrade.
http://www.lensrentals​.com …error-99-the-man-the-myth (external link)
40D Gripped, 50D, T2I Gripped, 5D Mark III Gripped, EF-S 18-55 IS, EF-S 55-250 IS
EF 28 f/2.8 IS, EF 40 2.8 STM, EF 50 f/1.4 USM,
EF 85 f/1.8 USM, EF 100 f/2.8 Macro USM, EF 24-105L f/4.0
EF 28-80 USM, the good one with metal mount and ring USM.
EF 28-80 USM V, EF 28-135 USM IS, EF 100-300 USM, EF 100-400L USM IS.
Rokinon 14 f/2.8
msowsun
"approx 8mm"
Gallery: 18 photos
Post edited over 8 years ago by msowsun.
Apr 01, 2015 20:44 |  #3
Which lens are you using? Can you try another lens?
John ­ from ­ PA
Joined May 2003
Apr 01, 2015 21:26 |  #4
Err 99 is somewhat generic and applies to quite a list of potential issues. Very often it is blamed on poor communication between the lens and camera body. I would suggest you go to http://www.lensrentals​.com …error-99-the-man-the-myth (external link) and then read through all 6 pages, then go to the sequence of diagnostics on pages 5 & 6 and see what can be learned. Yes, communication between lens and body can be an issue, but so can a weak (although indicting a full charge) battery. And that battery is potentially old when dealing with a 10D!
4N2RR
Joined Apr 2015
Apr 11, 2015 23:00 |  #5
Thanks guys for all your help. It happened to be my lens.
Got it all sorted out now.
1,953 views & 0 likes for this thread, 4 members have posted to it and it is followed by 2 members.
EOS 10D Error
1746 guests, 135 members online
