Thread started 02 Apr 2015 (Thursday) 14:06
Tether cord falling out
jeffdaypdx
Joined Jan 2013
Apr 02, 2015 14:06 |  #1
Hi
I tether my 5d to my mac, but when I tilt for vertical the cord falls out. I have taped it but it is awkward, is there a product out there that would help?
5D MarkIII | 17-40L | 50L | 85L | 70-200L
Scatterbrained
Gallery: 267 photos
Best ofs: 12
Apr 02, 2015 14:26 |  #2
Personally, I use a 90* usb and an L bracket, so there's issue with the weight of the cable. You could try a jerkstopper from tether tools. Or just gaf the cable to the camera. ;)
http://www.shop.tether​tools.com …-Cable-Management_c23.htm (external link)
500px (external link)
1x (external link)
instagram (external link)
Foodguy
Joined Mar 2012
Apr 02, 2015 15:55 |  #3
When I use my Canon tethered, I loop a rubber band on the chord and stretch the other end to connect either around the camera or on the ball head. Not the most sophisticated solution, but it does work.
My answer for most photography questions: "it depends...'
jeffdaypdx
Joined Jan 2013
Apr 03, 2015 10:57 |  #4
Thanks I will check both of those out.....
GeeMack
Gallery: 10 photos
Apr 03, 2015 13:31 |  #5
I've also seen a spring clip used to clamp the cord to the camera strap leaving some slack in the cord.
7D, 50 f1.8, 17-55 f2.8, 70-200 f2.8 II, 100-400 f4.5-5.6L, 2x TC III, 580EX II, 430EX, 568EX II, 622C
glmphotos.zenfolio.com (external link)
sincity
Joined Nov 2014
Apr 03, 2015 17:17 |  #6
Have you look at this ~~ http://www.lockcircle.​com/lockport/canon/ (external link)
Two ­ Hot ­ Shoes
Gallery: 383 photos
Joined Apr 2014
Apr 03, 2015 17:47 |  #7
I use a Jerk Stopper from TT
http://www.shop.tether​tools.com …-Camera-Support-JS020.htm (external link)
Although a small bit of string, or the one that looks like a climbing rope, around the cable (double half hitch) and the other ends throughout the strap loop and tied off would do the same job.
Fujifilm cameras and lenses.
Gear I use to create (external link)Instagram (external link)Blog (external link)
Coffee & Fujis (external link)About Capture One (external link)YouTube (external link)
DeuceJanisch
Apr 20, 2015 11:39 |  #8
Anything that takes the tension off the cable/port is a great help
I do a lot of tethered work and see way too many micro USB ports breaking from people not using jerk stoppers/cable wraps, so now I've added Velcro cable wraps to all th e tether cables to be looped through the camera strap loop:-)
2,415 views & 0 likes for this thread, 7 members have posted to it and it is followed by 3 members.
1323 guests, 168 members online
