6 KEY MISTAKES TO AVOID WHEN HANDLING SD CARDS TO MINIMIZE DATA LOSS from SLR Lounge:
http://www.slrlounge.com …ds-to-minimize-data-loss/![]()
Apr 10, 2015 13:00 | #1 6 KEY MISTAKES TO AVOID WHEN HANDLING SD CARDS TO MINIMIZE DATA LOSS from SLR Lounge: Website
chantu Senior Member 907 posts Likes: 26 Joined Aug 2006 Location: Bay Area More info | Apr 10, 2015 13:31 | #2 Really, this applies to ANY data card.
CyberDyneSystems Admin (type T-2000) More info | Apr 10, 2015 13:38 | #3 The "back filler" aspect was news to me. Makes sense, but I just had not considered. I often "free up space" by deleting in camera. GEAR LIST
joedlh Cream of the Crop 5,513 posts Gallery: 52 photos Likes: 684 Joined Dec 2007 Location: Long Island, NY, N. America, Sol III, Orion Spur, Milky Way, Local Group, Virgo Cluster, Laniakea. More info | Apr 10, 2015 14:07 | #4 I don't buy the back filler point. The operating system is designed to fill memory space and segment files as needed. That kind of technology has been around since the first hard drive was put in an IBM PC, maybe longer. It is true that saving files over deleted files can cause fragmented files. But the effect would be to slow file access, not break it. Nevertheless, I always reformat cards between shoots because having fragmented files doesn't feel right and it could get out of hand if you wait a long time between formatting. Joe
chantu Senior Member 907 posts Likes: 26 Joined Aug 2006 Location: Bay Area More info | Apr 10, 2015 14:38 | #5 Back filler? Don't think so. I've deleted photos in-camera only to recover them later. Flash memories AVOID writing to the same location to preserve write life of card.
Apr 10, 2015 16:06 | #6 chantu wrote in post #17512138 Really, this applies to ANY data card. Indeed! Website
Apr 11, 2015 03:02 | #7 thanks!
RDKirk Adorama says I'm "packed." More info Post edited over 8 years ago by RDKirk. | Apr 11, 2015 11:29 | #8 The important thing about formatting in the camera immediately before using the card is that it's the last, best opportunity to check the card for proper operation before using it. It used to be worthwhile to do a full format in a computer periodically, but I note that my 70D can do an in-camera full format...which I always do. TANSTAAFL--The Only Unbreakable Rule in Photography
eelnoraa Goldmember 1,798 posts Likes: 37 Joined May 2007 More info | Apr 16, 2015 03:33 | #9 I know for a fact that WET is not an issue for most card. The way SD card is packaged today is called SIP. Basically it is a molded plastic material with all flash and controller buried within. Now I am not saying to get the card wet purposely, but they can take a lot of element abuse and will survice. 5Di, 5Diii, 28, 50, 85, 16-35II, 24-105, 70-200F2.8 IS
someone0 Senior Member 436 posts Likes: 12 Joined Jul 2014 More info | Apr 16, 2015 04:15 | #10 I thought these are common senses. But there are trade off for everything though. I mean for example, in the dual CF & SD slot, you have a choice of better performance w/ CF at the cost of price and easier to bend the pin every time you take the card in and out of the camera. Which is another aspect, some people will rather have a fresh battery and transfer file using camera as card reader vs taking the card out of the camera and risk damage the pins. These are choice every one have to make, some may make sense for one, while the other may choose the oppose view. Not everything is clear cut. But yes, things like water are pretty obvious. But if you have to pick one, I rather choose water vs sea water/soda/coffee. Also many professional grade cards are design to withstand some water, meaning if you drop your camera in the water, your camera maybe dead, but your images will survive. And then you let your insurance take care of the gear finance.
| Latest registered member is semonsters 1507 guests, 129 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
