Thread started 10 Apr 2015 (Friday) 23:12
gear question
macobee
Apr 10, 2015 23:12 |  #1
Hi All,
I have a new set of extension tubes and want to try a bit of macro photography, but am doubting a few things.
1. which lens to use? the 100 MM macro f2.8 EF i have or the 70-200 F2.8 USM......if i go with the macro i am stuck with focal length, with the zoom i think its easier to use with a tripod as you dont have to place the tripod Exactly within focus range....please commment..?
2. bother to make a flash bracket DIY or is it better to get a good one bought, sturdier, more rugged for in the field?
Thanks!
Marco
http://www.flickr.com/​photos/marcoveringa/ (external link)
rgs
Gallery: 176 photos
Apr 10, 2015 23:25 |  #2
I would always choose the macro lens over the zoom if I thought the focal length was right for the photo I wanted to make. A macro focusing rail may help with precise framing with the 100mm. You can probably pick one up used for cheap.
Canon 7d MkII, Canon 50D, Pentax 67, Canon 30D, Baker Custom 4x5, Canon EF 24-104mm f4, Canon EF 100mm f2.8 Macro, Canon EF-S 10-22mm f/3.5-4.5, 70-300mm f/4-5.6 Di VC
The Singular Image (external link)Richard Smith Photography (external link)
Richard Smith Real Estate Photography (external link)500PX (external link)
Fine Art America (external link)
Archibald
You must be quackers!
Gallery: 789 photos
Apr 10, 2015 23:59 |  #3
Try the macro lens first. Focal length doesn't have the same importance in macro shooting as in regular shooting. Perspective and framing are usually not significant factors. Working distance and lighting are. If the 100mm does not approach the subject too closely and if it allows the lighting you need, then I think it will work great.
The zoom will give weird results with extension tubes. It's because the marked focal lengths of the lens change when focusing. That impacts the effect of the extension tubes. It may be tricky to get the magnification you want.
You might find it hard to do macro on a tripod unless you have a focusing rail. You will need to move either the tripod or the subject small distances to achieve focus. This gets harder the higher the magnification. With flash, you won't need a tripod to freeze motion. Hand-holding with a flash might be better unless you need precise framing or are doing focus stacking. For that, use a tripod, but then you will need the rail.
I find for macro outdoors, it is way more practical to hand-hold. If you do this, the 70-200mm will get heavy fast.
Lighting can be quite a challenge in macro, depending on the magnification. (Everything gets harder as you go to higher m.) Tons have been written on the Web and here at POTN on flash diffusers for macro photography. Do a little search to see what might be suitable for you.
You have the lenses, so I suggest you do some trials to get some experience and see what issues you encounter.
Aswald
Joined Oct 2013
Apr 11, 2015 00:36 |  #4
100mm macro.
760 views & 0 likes for this thread, 4 members have posted to it and it is followed by 2 members.
gear question
1340 guests, 122 members online
