FORUMS Post Processing, Marketing & Presenting Photos The Business of Photography
Thread started 12 Apr 2015 (Sunday) 21:29
Date and Time on Images
AndrewCarlton
Joined Apr 2015
Apr 12, 2015 21:29 |  #1
This is a strange questions, but I actually need the date and time on my images! I have a Canon 5D Mark II and have never ever desired the date and time on my images, but I have a need for it and for the life of me, cannot figure out how, if it's even possible, to get that function on my camera. I know the date and time is digitally stored within the image, but I need it on the image for viewing. Any help is appreciated.
itsallart
Gallery: 1095 photos
Joined Jan 2015
Apr 12, 2015 21:37 |  #2
AndrewCarlton wrote in post #17514874 (external link)
Don't know about your camera, but on mine I see it on the LCD screen
Renata
Seeing lights and shadows is an art :)
My Vinyl Source (external link)Tanami Muse (external link)
500px (external link)
Face Masks on Etsy (external link)
itsallart
Joined Jan 2015
Apr 12, 2015 21:49 |  #3
sorry, forgot yo attach the image
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/04/2/LQ_722490.jpg
Image hosted by forum (722490) © itsallart [SHARE LINK]
Renata
AndrewCarlton
Joined Apr 2015
Apr 13, 2015 05:54 as a reply to  @ itsallart's post |  #4
No, I am talking about when you print the image. I need it on the print. This is for court purposes.
frozenframe
Gallery: 189 photos
Joined Jun 2013
Post edited over 8 years ago by frozenframe.
Apr 13, 2015 07:40 as a reply to  @ AndrewCarlton's post |  #5
Do you have LR? If so there is a way to print EXIF data of your choosing below the image.
In the Print Module, go down to the Photo Info,
IMAGE: https://farm8.staticflickr.com/7636/17133910735_09e5fda81d.jpg
click on it and scroll down to Edit.
IMAGE: https://farm8.staticflickr.com/7629/17133276921_e6ea3ab2ed.jpg
Select Edit and the Text Template Editor will open.
IMAGE: https://farm8.staticflickr.com/7636/16946376340_e052dd9c83.jpg
When inserting the fields, you will need to manually insert the Colons and space.
In the Numbering section, the bottom drop-down you can insert the Date and Time. This is how it will print.
IMAGE: https://farm8.staticflickr.com/7693/17133276501_0f35177ff3.jpg
Ron
My Gear List
AndrewCarlton
Joined Apr 2015
Apr 13, 2015 16:12 as a reply to  @ frozenframe's post |  #6
Hmm ok. I am curious if the courts would consider that manual manipulation of the image. That's what I'm concerned about.
frozenframe
Gallery: 189 photos
Joined Jun 2013
Apr 13, 2015 16:50 |  #7
Ok, well you probably will have to testify. Part of that testimony will be to certify the date and time information printed is the same and comes directly from the Meta data. This is done by the software, and you do not type that onto the prints. LR being a DAM / Database program, utilizes fields, just like any database program. The only input you had was to select the appropriate fields from the meta data. The meta data is something that is generated by the camera, not you. Simple question, Did you alter the meta data? Nope. Is it possible with LR, I don't think so, without leaving some sort of record of that occurring. If the court would like, they can compare the printed date and time, with that of the original digital files.
Even if you can find a program that will print (burn) that info onto the front, you will still have to certify/authenticate it via testimony.
Ron
My Gear List
Willie
Joined Feb 2004
Apr 14, 2015 09:04 |  #8
How are you manipultaing the image? You are just changing print options. The file does not get changed.
frozenframe
Gallery: 189 photos
Joined Jun 2013
Apr 14, 2015 10:04 |  #9
Willie wrote in post #17516683 (external link)
Exactly. The opposition (Defendant or Plaintiff) would question IF it was possible to alter that information. Like I stated earlier, LR does not provide that option to alter that Meta Data.
Also it is extremely critical to maintain the integrity of the original files. I would suggest that any media, CF, SD, cards be secured. Nothing removed or added to those cards. It can be an argument, and possibly lead to the prints being not admitted, if the original media can be shown to have been altered. I hope the OP did not transfer the files to his computer then format the cards the images were captured to. If so the OP may have a very long day on the witness stand. Andrew, you do have the training and experience to testify as an expert, don't you?
EDITED
Oops, I did finally find where the Meta Data, Date and Time can be changed.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/04/2/LQ_722711.jpg
Image hosted by forum (722711) © frozenframe [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/04/2/LQ_722712.jpg
Image hosted by forum (722712) © frozenframe [SHARE LINK]
Ron
My Gear List
Dan ­ Marchant
Gallery: 19 photos
Joined Oct 2011
Apr 14, 2015 10:13 |  #10
AndrewCarlton wrote in post #17515184 (external link)
Did the court tell you that they need it? It is information added to the image after the fact. It doesn't prove anything, you could add any date.
I believe that most court require the photographer to provide a sworn affidavit that the image were taken at the time and in the place stated. That is going to do a lot more to convince a court than a date added to the image.
Dan Marchant
frozenframe
Gallery: 189 photos
Joined Jun 2013
Post edited over 8 years ago by frozenframe. (2 edits in all)
Apr 14, 2015 10:24 |  #11
Dan Marchant wrote in post #17516770 (external link)
THIS^
FWIW, I Changed the Date/Time on an image, went to the print module and the new date and time was shown on the print. LR does show in the Meta Data Panel, this change. Showing the Original "Capture Time" and the changed time.
Taking this one step further, I opened the Raw file that I had changed, in another program (Corel PSP X6), and found the Meta Data reflected the original Capture date/time, not the changed one. However PSP allows changing that information too. So I'm now thinking that most programs that have the ability to do Raw conversions, also allow the altering/changing of Meta Data.
So simply burning and/or printing that on a photo is not going to be sufficient. It's you swearing that you have not altered it.
Just a little side note, I'm not an attorney, and this should be addressed by an attorney, not an internet web board. However I was a LEO for a couple of decades, and during that time was an evidence custodian for a department. Back then the digital cameras were just coming on the scene. We used Sony Digital Mavica, used floppy disks. The disks were turned into the evidence facility, and held until the case was disposed of.
Ron
My Gear List
mclaren777
Joined May 2012
Apr 14, 2015 11:51 |  #12
There's a reason why this kit exists...
http://www.bhphotovide​o.com/c/product/319787​-REG/ (external link)
A simple comparison of sensor technology: Nikon vs. Canon (external link)
A technical comparison of sensor technology: Exposure Latitude (external link)
breal101
Apr 14, 2015 13:40 |  #13
I agree with you. I haven't done any legal work in the digital era but did a lot back in the film days. A few cases involved fatalities and millions of dollars. I had a rubber stamp that certified that the photograph was taken by me and was true and correct. I stamped the back of each print with that and a date stamp and signed each print. Never had a problem with the other side, they agreed to stipulate the pictures and no judge ever had problem with it either. This was all in civil courts.
BTW: I was called to court several times but never had to testify.
"Try to go out empty and let your images fill you up." Jay Maisel
Tom ­ Reichner
"That's what I do."
Gallery: 213 photos
Location: from Pennsylvania, USA, now in Washington state, USA, road trip back and forth a lot
Post edited over 8 years ago by Tom Reichner.
Apr 14, 2015 18:52 |  #14
There was someone on here a couple years ago with the same type of situation. It happens that the court did not say that they needed the date and time on the printed images - the photographer just assumed he would need that. Don't sweat this unless the court itself tells you that it is necessary.
By the way, anyone can put any date they want into the original EXIF information. How? Just change the date & time in your menu options, then snap away! I don't think any court officials/lawyers in their right mind would accept EXIF data as absolute, indisputable "proof" about anything - it is too easy to make it say anything you want.
idkdc
Joined Oct 2014
Apr 14, 2015 19:16 |  #15
mclaren777 wrote in post #17516900 (external link)
Holy hell, that's expensive. Never knew it existed on the consumer market. Thanks for the link.
I like big cinema cameras and I can not lie
You other brothers can't deny
3,564 views & 0 likes for this thread, 12 members have posted to it and it is followed by 5 members.
1835 guests, 126 members online
