Hi,
I have a little slack issue with the focus of my lens 35mm 1.4 Samyang/Rokinon/Bower (Canon mount). The back part of the lens (close to the sensor) move when the lens rotate from up to down. Also, the same part does not move when I rotate slightly the focus ring (back and forth), but move when I make longer rotation.
I found two DIY solution
1. https://www.flickr.com …861364424/in/photostream/
I don't exactly get its instructions, there is some vocabulary issue, and not many photos.
2. http://www.noiseandpictures.com …xed-or-modified-gear.html
The solution is for the 24mm, but look like the same problem, I guess same/similar solution could work.
Which path would you take?
Best regards,
