Thread started 16 Apr 2015 (Thursday) 21:21
7d mkii and bird photography
Pauhana
Apr 16, 2015 21:21 |  #1
going out to play with my new mark ii in the morning to get a feel for the camera. Have been using a 7d mki for several years. My primary lens is a 400 5.6 L. Shoot a lot of bird in flight, mostly shorebirds, swallows (at least attempt to shoot in flight) And of course smaller birds warblers, sparrows, etc that may be static or moving through trees. Any suggested settings to try with this setup? Have read over the canon PDF on the various cases thanks link found on this form. Know there will be a learning curve on this new camera and hopefully migration will pick up so I can put it to the test.
Randy
Confused and Prone to Wander.........
Traded Canon gear for
Olympus OMD OM-1, Olympus 100-400, Olympus 12-100, Panasonic 15 1.7, Olympus 45 1.8
pknight
Gallery: 39 photos
Joined Feb 2006
Apr 17, 2015 06:24 |  #2
http://www.learn.usa.c​anon.com …os7dmk2_afGuide​book.shtml (external link) :-)
Digital EOS 90D Canon: EF 50mm f/1.8 II, EF 50mm f/2.5 Compact Macro, Life-Size Converter EF Tamron: SP 17-50mm f/2.8 DiII, 18-400mm f/3.5-6.3 DiII VC HLD, SP 150-600 f/5-6.3 Di VC USD G2, SP 70-200 f/2.8 Di VC USD, 10-24mm f/3.5-4.5 DiII VC HLD Sigma: 30mm f/1.4 DC Art Rokinon: 8mm f/3.5 AS IF UMC
MikeWa
Gallery: 89 photos
Joined Apr 2012
Post edited over 8 years ago by MikeWa. (3 edits in all)
Apr 17, 2015 20:16 |  #3
I cannot tell you the best settings but I can say My BIF pictures have improved dramatically with the 7D-II vs the 7D-I. This is what I use.
Manual Mode 1/1600 F-8 and I set up the aperture to not go below f-8. EC+1 I can dial up more or less as needed. I set the EC to be controlled by the Quick Control dial so I could change it easily as lighting conditions change. ISO Auto, AI Servo, Partial metering, high speed continuous shutter. Case 2 modified as follows. Tracking Sensitivity -1 step, Accel Decel +2, Auto Switching unchanged. Auto focus at 65 point with center spot highlighted. I saved everything to Custom Mode 3 so I can get back there quickly. Also I can easily change any of these setting as conditions require.
As I said these may not be the best settings. Others may have something better. But this works for me.
Good Luck
Mike
Mike...G9; 7D; 7D Mark II; EF-S 10-22mm; EF-S 18-135mm IS STM; EF 28-300mm F3.5-5.6L; EF 70-300mm IS USM; EF 70-200mm F2.8L IS-II; EF 100-400mm f4.5-5.6L IS; EXT 1.4-II & 2.0-III; The more I learn the less I know.
JM45ACP
Gallery: 50 photos
Joined Dec 2011
Apr 19, 2015 16:11 |  #4
Try this one
https://photographylif​e.com …canon-7d-mark-ii-settings (external link)
5D MARK IV== 7D Mark II==7D == EF 24-105mm f4L IS USM == EF 100mm f/2.8LMacro==70-200mm f2.8L IS II USM == EF 70-300mm f/4-5.6L IS USM UD == EF 100-400mm f/4.5-5.6L IS II USM==Speedlite 430 EX II PHOTO EDITING OK
Trvlr323
Apr 19, 2015 16:15 |  #5
This article was written for BIF on the 5D3 but it applies to the 7D2 very well. I'm sure you'll find it helpful.
http://garyluhm.net …us-ai-servo-birds-flight/ (external link)
Sometimes not taking a photograph can be as problematic as taking one. - Alex Webb
JM45ACP
Gallery: 50 photos
Joined Dec 2011
Apr 19, 2015 16:47 as a reply to  @ Trvlr323's post |  #6
Thanks that was a good read had some useful info that pertains to the 7D MK II.
Pauhana
Apr 20, 2015 19:04 |  #7
Thanks great info. For right now I seem to be getting better results using case 2. Really am liking this new camera. Migration slow so spent yesterday chasing butterflies. Very pleased with results
Randy
4,707 views & 0 likes for this thread, 5 members have posted to it and it is followed by 3 members.
909 guests, 118 members online
