Thread started 18 Apr 2015 (Saturday) 17:53
7D Mark II - On reviewing images how can I tell which autofocus case I used?
peeps27
Joined Mar 2003
Post edited over 8 years ago by peeps27.
Apr 18, 2015 17:53 |  #1
Beginners question. I have tried searching the web but cannot find an answer to this (I am sure there is a simple answer). When I download images onto my PC how can I determine which of the six case settings was used for autofocus? I cannot seem to find a way in Lightroom or Photoshop Elements or Canon's bundled software that shows this information.
AZGeorge
Apr 19, 2015 18:27 |  #2
For many cameras the focus mode is included in the EXIF.
There are many EXIF viewers available. I happen to use the viewer included in Irfanview, a free and rather good image viewer and limited editor.
George
Democracy Dies in Darkness
GregDunn
Joined Mar 2013
Apr 19, 2015 21:03 |  #3
Canon's DPP will show you the AF case used for each shot. And it's included free with every camera.
Canon 1Dx | 5D3 | 7D2 | 6D | 70-200L f/2.8IS | 70-200L f/4 | 24-70L f/2.8 | 24-105L f/4IS | 100-400L f/4.5-5.6IS | 17-55 f/2.8IS | 50 f/1.8 | 28-105 f/3.5-4.5 | 4x Godox AD360
John ­ from ­ PA
Joined May 2003
Post edited over 8 years ago by John from PA.
Apr 19, 2015 21:17 |  #4
GregDunn wrote in post #17524333 (external link)
As Greg said, DPP will tell you virtually everything. Simply click the image, then right click the mouse, then select Info (at the bottom) or as an alternative, with the image selected, hit the Ctrl-I hotkey sequence. Remember I = Info.
peeps27
Joined Mar 2003
Apr 20, 2015 03:23 as a reply to  @ John from PA's post |  #5
Thanks guys. Problem solved!!!
RodS57
Gallery: 184 photos
Joined Jun 2014
Apr 21, 2015 10:37 |  #6
Can anyone tell me which field in the exif info is related to the focus case used. My default viewer has a sidebar which shows exif info items I've selected without having to view the actual exif info in another window.
Rod
>>> Pictures? What pictures? <<<<
peeps27
Joined Mar 2003
Apr 21, 2015 15:07 as a reply to  @ RodS57's post |  #7
It is called AF configuration tool. As per above instructions, open DPP4, open image and then press Ctrl and I and this box appears.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/04/3/LQ_723956.jpg
Image hosted by forum (723956) © peeps27 [SHARE LINK]
RodS57
Gallery: 184 photos
Joined Jun 2014
Apr 21, 2015 16:50 as a reply to  @ peeps27's post |  #8
Thanks. My viewer doesn't identify that item.
Rod
John ­ from ­ PA
Joined May 2003
Apr 21, 2015 17:02 |  #9
RodS57 wrote in post #17526852 (external link)
Rod
What are you using for a viewer? Be specific with version numbers.
RodS57
Gallery: 184 photos
Joined Jun 2014
Apr 21, 2015 20:48 as a reply to  @ John from PA's post |  #10
I use Debian Linux and normally use gwenview for quick viewing as it is Very close to irfan view in use which means fast. Out of curiosity I opened up fotoxx and copied the exif info to a text file to compare to the info displayed by gwenview. A lot more unidentified tags in gwenview. The most interesting thing I found is the exif info contains the camera temperature although I have no idea how accurate it is. Found this in fotoxx.
I have the canon software on an win XP machine but only turn it on as required. As required means to load pictures onto my iPad
Rod
ppmax
Apr 21, 2015 21:25 as a reply to  @ RodS57's post |  #11
I use exiftool to add the case and af area mode to all my RAW images as keywords. That way I don't have to open DPP just to look at that stuff.
Pp
2,195 views & 0 likes for this thread, 6 members have posted to it.
501 guests, 122 members online
