Thread started 27 Feb 2006 (Monday) 22:44
Off camera flash
dandan
Joined Jan 2005
Feb 27, 2006 22:44 |  #1
what is the cheapest thing i can get that will remotely fire my (non canon) flash? im looking for something that will fire it from about 5 feet away. I realy dont care how its dont, or if i need a direct line of sight to the flash to fire it, as long as it fires
30mm, 50mm, 85mm, and some zooms here and there.
All nikon :D
- www.dan-mcnair.com (external link) - Webdesign and Photography (external link)
cosworth
I'm comfortable with my masculinity
Feb 28, 2006 01:05 |  #2
Off camera show cord. Not quite 5 feet but close.
Look at this as well:
https://photography-on-the.net …light=shoe+cord​+extension
people will always try to stop you doing the right thing if it is unconventional
Full frame and some primes.
tim
Light Bringer
Feb 28, 2006 05:08 |  #3
Perhaps get a couple of cheap vivitar units with optical triggers, run them in manual, it's cheap and reasonably powerful.
Mark_48
Feb 28, 2006 06:10 as a reply to  @ tim's post |  #4
You didn't mention what camera and flash you have. Could you use a simple PC cord (cheap)connection? If so, just be absolutely sure your camera can handle the flash triggering voltage. Some Canons have a 6 volt limit.
This won't give you auto flash exposure so you'll need to meter the flash or find the right exposure by trial and error with the camera in set in manual.
Megapixels and high ISO are a digital photographers heroin. Once you have a little, you just want more and more. It doesn't stop until your bank account is run dry.
dandan
Joined Jan 2005
Mar 01, 2006 04:14 as a reply to  @ tim's post |  #5
I already have an external flash, im looking for something to fire it.
For this stuff i normaly use a fuji s7000 and a national/panasonic (forget the model name) flash.
All nikon :D
tim
Light Bringer
Mar 01, 2006 05:27 |  #6
Get an optical trigger, and a cheap flash unit to mount on your hotshoe.
SkipD
Joined Dec 2002
Mar 01, 2006 06:24 as a reply to  @ dandan's post |  #7
I will repeat a question from above - what camera are you trying to use?
Nobody can properly help you with suggestions until that is known.
The other thing that is very important to know is what the sync voltage of the flash unit is. Having the make/model can help, but you could also measure the voltage when the flash is ready to fire.
Skip Douglas
Mark_48
Mar 01, 2006 16:02 as a reply to  @ SkipD's post |  #8
Skip,
After a quick Google search, I'm guessing he may have a Fuji Finepix S7000 camera. It does have a flash hot shoe (no PC connection). The flash is sort of an unknown.
There are adapters made that could achieve a wired connection with a PC cord for you that are availble through B&H Photo. Again if it's wired, know what voltage your camera can handle so you don't fry it's electronics. A Wein Safe Sync can be used to "regulate" a high flash voltage to something safe for a camera.
As Tim mentioned you could also use an optical trigger. I bought several through ebay that work well with my Canon 20D firing a Sunpak 383 as a master to an optically triggered 383 remotely.
http://cgi.ebay.com …30084QQrdZ1QQcm​dZViewItem (external link)
SkipD
Joined Dec 2002
Mar 01, 2006 17:03 as a reply to  @ Mark_48's post |  #9
Mark_48 wrote:
Skip,
The guessing is why I asked.... This is essentially a Canon forum, and I wondered if he had a new Canon camera of some sort. Oh well.... Maybe the OP will reply with some details.
Skip Douglas
dandan
Joined Jan 2005
Mar 02, 2006 21:40 |  #10
OH OH, sorry, I use a fujifilm s7000 camera. not cannon, sorry. (though i am planning on upgrading to a 30d soon :D)
ill measure the voltage from my flash tonight
All nikon :D
1,307 views & 0 likes for this thread, 5 members have posted to it.
Off camera flash
2105 guests, 97 members online
