Thread started 27 Feb 2006 (Monday) 22:57
Mounting backdrop in garage studio
moondragon
Feb 27, 2006 22:57 |  #1
Hey all,
Anyone have suggestions/tips on mounting a backdrop in a garage... I'm thinking about something from the ceiling to put a rod/dowel on for the backdrop, but I'm pretty dumb when it comes to these things.
any have experience with this?
cheers,
moon
akiwi
Joined Jun 2005
Feb 28, 2006 00:11 |  #2
Two chains with a hook in the end. You can unhook them, and using the links change the height.
Peter
www.PeterHansenPhoto.d​e (external link)
Gear:: Canon 7D & 350D :: EF 24-70 F2.8L :: EF-s 17-85:: 50mm 1.8 ::70-200 F4L ::100 F2.8 Macro:: Sigma 10-20 :: 580EX:: Elinchrom studio lights:: loads of other bibs & bobs.
SkipD
Joined Dec 2002
Feb 28, 2006 05:55 |  #3
Use a piece of electrical ("thinwall") conduit - 3/4" or larger - suspended by clips, chains, or whatever. The conduit comes in 10-foot sections and is very inexpensive.
Skip Douglas
bolantej
Feb 28, 2006 12:16 |  #4
some people use rope.
Ross ­ McT.
Joined Jun 2005
Feb 28, 2006 12:49 |  #5
I second the PVC comment, except use the thick tubes (grey ones up here). The white tubes are too thin. They cost double, but that is still only $5.00 CDN for a 10' length.
The fittings are where it costs you
I'll post a picture of my set up this time tomorrow.
I have 2 parallel tubes running 9' wide so that I can have either 2 rolls of seamless up at the same time (one black, one white) or a roll of seamless and a bunch of fabric hung off it.
Ross McT.
Digital: 50D, Rebel XT+Grip, EF-S 10-22, 17-85, 18-55, EF 70-300IS,50mm f1.8,
Just trying to master what I have.
moondragon
Feb 28, 2006 13:00 |  #6
look forward to the pic Ross... thanks :)
redbutt
Joined Aug 2001
Feb 28, 2006 16:53 as a reply to  @ moondragon's post |  #7
I found this neat little pulley system at Lowes for $25. The packaging called it a system for hanging bicycles from the ceiling of your garage. You just have to make sure you screw it into a ceiling joist for maximum weight load capability, but it works great. Here's a pic of it in my garage. It holds things up to 10ft wide on a wood bar that I also got at Lowes secured with A clamps.
https://photography-on-the.net …mentid=50421&d=​1137446526
SuzyView
Feb 28, 2006 17:32 |  #8
From the ceiling hanging from 2 short chains, a very long metal curtain rod. I think buying an inexpensive metal frame is worth it. You can keep it all in a box like what I have and it costs only around $100. The rod is 12 feet long and adjustable. I can hang paper, muslin, or any other drape. It's great.
SkipD
Joined Dec 2002
Feb 28, 2006 17:37 as a reply to  @ Ross McT.'s post |  #9
Ross, if you were commenting on my suggestion of electrical thinwall conduit, I was referring to what is officially known as EMT - Electrical Metallic Tubing. It is made of steel, but is much thinner than water pipe or "rigid" electrical conduit.
Skip Douglas
Ross ­ McT.
Joined Jun 2005
Feb 28, 2006 17:47 as a reply to  @ SkipD's post |  #10
I had it in my mind that you were refering to Nonmetallic Mechanical Protection Tubing (NMPT) its also refered to as electrical conduit.
EMT is nice and strong, but I have found that handling the tubes can be a pain. Literally!
The 0.050" wall thickness can be sharp if proper steps are not taken to ensure the ends are capped. While PVC can simply be sanded to a nice round end. if your changing rolls or backdrops alot, i personally would take safety into account.
Either way, they both work well and are much cheaper than a manufactured hanger.
Ross McT.
Ross ­ McT.
Joined Jun 2005
Mar 01, 2006 10:21 |  #11
Here is the design that I've gone with for mounting a backdrop in my basement.
The grey portions are 3/4 PVC electrical conduit.
At the joint where the roll attaches to the frame, there is a small hole drilled in the fitting to constrain the tube. I've used a chunk of 14gauge copper wire. I will be replacing it with a quick pin at some point.
The bottom is a 90° angle without a tube inserted. This spot will be for when I get either a 2nd roll of paper or some fabric backdrops.
The cross bar sits between the rafters and is easily removed when disconnected from the other side.
Ross McT.
Dante ­ King
"Cream of Corn" BurgerMeister
Joined Jan 2005
Mar 01, 2006 22:11 |  #12
Damn and I just paid large dollars for a manfrotto system! DOH!!!!
Dante
I am not an Lcoholic. Lcoholics go to meetings!
6,305 views & 0 likes for this thread, 8 members have posted to it.
2105 guests, 96 members online
