A customer had me grab some shots of her daughter.
I tried some OCF for dramatic effect. Should have thought a bit more about the background though...
Then I broke out the 14mm...
And got plenty of shots on old faithful 70-200
Apr 24, 2015 12:44 | #1 A customer had me grab some shots of her daughter. Then I broke out the 14mm... And got plenty of shots on old faithful 70-200 1D MkIV | 1D MkIII | 550D w/grip & ML| EF 70-200mm f2.8L| EF 24-105mm f4L IS | Canon EF 100-400mm f/4.5-5.6L IS | Samyang 14mm f/2.8 IF ED UMC | 430EXii | EF 50mm f1.8
hdgiles Member 160 posts Likes: 18 Joined Feb 2009 Location: Athens, Georgia More info | Apr 24, 2015 14:15 | #2 The first one has the pop-up in the background right behind her head and is distracting. The second one has a clean background and she is positioned correctly in the frame but I think you can crop in closer. In the third one you cropped the right hand runner in half - almost. This looks bad. It would look better with both runners, or one runner.
Much appreciated and agreed. I could have set that flash up anywhere, and I'm not sure why I set it up in that location. Next time... 1D MkIV | 1D MkIII | 550D w/grip & ML| EF 70-200mm f2.8L| EF 24-105mm f4L IS | Canon EF 100-400mm f/4.5-5.6L IS | Samyang 14mm f/2.8 IF ED UMC | 430EXii | EF 50mm f1.8
Firehouse Senior Member More info | Apr 24, 2015 18:12 | #4 My advise is to isolate the subject you are shooting. As a parent myself I would not buy a picture that has a stranger in it to display in my house....just my two cents. Rich
waterrockets THREAD STARTER Goldmember More info Post edited over 8 years ago by waterrockets. (2 edits in all) | Yep, I got a dozen or so isolated too. Full body and cropped tight. I asked the customer if she would rather just do action shots outside of competition, and she said she wanted it at a meet. There are probably several factors there, but I'm sure it's a combination of the intensity of a finish against a competitor, as well as seeing the competition. 1D MkIV | 1D MkIII | 550D w/grip & ML| EF 70-200mm f2.8L| EF 24-105mm f4L IS | Canon EF 100-400mm f/4.5-5.6L IS | Samyang 14mm f/2.8 IF ED UMC | 430EXii | EF 50mm f1.8
| Latest registered member is semonsters 1457 guests, 134 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
