Thread started 25 Apr 2015 (Saturday) 20:49
how to remove annoying dust specks on rubber ring of lenses?
the.forumer
Joined Oct 2011
Apr 25, 2015 20:49 |  #1
IMAGE: http://i.imgur.com/C0GO2dJ.jpg
After using my lenses for a couple of months, it will attract a lot of dust specks and not look as good as it was when I first bought them new. What is the best way to restore the condition of the rubber ring to a brand new condition?
Now, I understand that some of you would say that lenses are meant to be used/abused, so what for keep it in pristine condition? Don't get me wrong - I still use it on a daily basis regardless of its exterior condition, but just prefer it to be clean.
constructive suggestions welcome!
Trvlr323
Apr 25, 2015 20:55 |  #2
if you go to your local hardware store you'll find silicone based spray lubricants that are safe for use on rubber. They are recommended for use on window seals, etc. and can often be found in the automotive section. They are great for cleaning up those rubber rings, removing built up dirt and grease and making them nice and black again.
Sometimes not taking a photograph can be as problematic as taking one. - Alex Webb
groundloop
Joined Jun 2012
Apr 25, 2015 21:00 |  #3
Armor-All applied lightly with a Q-tip.
phantelope
Apr 25, 2015 21:04 |  #4
I'd just use a q-tip with a bit of water, if that doesn't work maybe a bit of gentle soap. If I'd care about that. If you use soap or something else, I'd suggest to use plain water to clean residue off afterwards. I don't usually trust things that say 'safe for...' all that much.
40D, 5D3, a bunch of lenses and other things :cool:
05Xrunner
Goldmember, Flipflopper.
Gallery: 52 photos
Apr 25, 2015 21:37 |  #5
Just get a small hobby paint brush and brush them away if it's just dust. Now if it's getting little white from sweat over time. I just pull the ring off and wash it in the sink with dish detergent. Then all my gear gets coated with Ultima interior guard+
My gear
R7, 7D, Canon RF 14-35 f4L, Canon RF 50 1.8 STM, Tamron 70-200 G2, Canon 100-400LII, Canon EF-RF
bumpintheroad
Self-inflicted bait
Gallery: 21 photos
Joined Oct 2013
Apr 26, 2015 05:37 |  #6
I would be concerned about using any kind of lubricant or petroleum-based product on the lens that might picked-up on your hands and inadvertently transferred to the lens surface. I once had a filter stuck to one of my lenses and tried using silicon spray to lubricate the threads. While that helped get the filter off, some of the silicon got onto the surface of the filter and destroyed the coating. I was very happy that none got on the lens itself.
-- Mark | Gear | Flickr (external link) | Picasa (external link) | Youtube (external link) | Facebook (external link) | Image editing is okay
Derf
Apr 26, 2015 08:17 |  #7
Personally I would go with the sink
Canon 7D / Canon 40D / Opteka 6.5mm / Sigma 18-35 1.8 / Canon 50mm 1.4 / Canon 50mm 1.8 / Tamron 28-75 2.8 / Tamron 70-300VC
WWW.LongIslandWallpape​rs.com (external link)
05Xrunner
Gallery: 52 photos
Apr 26, 2015 09:59 |  #8
bumpintheroad wrote in post #17532880 (external link)
That's why armor all should not be used it's an oily junk product that gets all your hands. Use a high quality product like Ultima, 303 aerospace, carpro PERL. They dry clean and no oil left behind just proper protection. I do professional detailing as a hobby so always have high end stuff for cleaning and protecting.
My gear
John_T
Gallery: 127 photos
Joined Jun 2003
Apr 26, 2015 10:12 |  #9
A toothbrush and a dampened terrycloth microfiber cloth, no more, and that should do the job. Getting OCD about cleaning photo gear is likely to do more harm than good over time.
Canon : EOS R : 5DIV : 5DS R : 5DIII : 7DII : 40 2.8 : 50 1.4 : 35L : 85L : 100L IS Macro : 135L : 16-35L II : RF-24-105L IS : 70-200L II : 100-400L IS II : 1.4x & 2x TC III : 600EX-RT : 580EX : 430EX : G1XII : Markins Q10 & Q3T : Jobu Gimbal : Manfrotto Underware : etc...
msowsun
"approx 8mm"
Gallery: 18 photos
Post edited over 8 years ago by msowsun.
Apr 26, 2015 14:50 |  #10
I have used a toothbrush and some Isopropyl Alcohol with good results.
LV ­ Moose
Moose gets blamed for everything.
Gallery: 223 photos
Post edited over 8 years ago by LV Moose. (4 edits in all)
Apr 26, 2015 14:55 |  #11
I wipe down my lens bodies and camera bodies with a rag (old T-shirt) lightly dampened with distilled water. For grooves in the lens's rubber rings I use a soft tooth brush if I can't get the damp rag in there.
Moose
Gear... Flickr (external link)...Flickr 2 (external link)...
Macro (external link)...Hummingbirds (external link)
Aircraft (external link)
Aswald
Joined Oct 2013
May 09, 2015 01:50 |  #12
John_T wrote in post #17533092 (external link)
Second this.
A very light application of 3M's Vinyl Protector will go a long way with any butyl rubber. A very small bit (and I mean barely enough) on a microfiber cloth and rub in. It'll keep gunk and oxidative process away for years.
For more stubborn white stains, use a soft eraser and slowly rub on affected areas. It'll put a smile on your face and it works on rubberized surfaces on the camera body too.;-)a
elliott44k
May 09, 2015 12:25 |  #13
The only thing is, you can spend time to remove it, but they'll just come right back.
2,747 views & 0 likes for this thread, 12 members have posted to it and it is followed by 3 members.
1504 guests, 134 members online
