I need to micro focus adjust my Canon 7d Mark ii and Canon 600mm f4 is. Would you leave the IS on or off when on a tripod when doing the testing ?
Thanks Troy
Apr 27, 2015 21:17 | #1 I need to micro focus adjust my Canon 7d Mark ii and Canon 600mm f4 is. Would you leave the IS on or off when on a tripod when doing the testing ?
Apr 28, 2015 04:30 | #2 troyhattemer wrote in post #17535112 I need to micro focus adjust my Canon 7d Mark ii and Canon 600mm f4 is. Would you leave the IS on or off when on a tripod when doing the testing ? Thanks Troy It should make no difference. Why not try both and tell us what happens? Frank Hollis - Retired mass spectroscopist
fordmondeo I was Soupdragon in a former life. More info | Apr 28, 2015 05:50 | #3 I would turn it off assuming you'll be using a static subject for tuning. Vaginator9000
GregDunn Goldmember 1,289 posts Likes: 132 Joined Mar 2013 Location: Indiana More info | Apr 28, 2015 10:48 | #4 As long as the IS gyros are spun up before you take the test shots, it should only improve the stability of the optics. Older Canon lenses had a sensor which would introduce jitter into the IS system if the lens were held perfectly still; they've fixed that in all modern units. Canon 1Dx | 5D3 | 7D2 | 6D | 70-200L f/2.8IS | 70-200L f/4 | 24-70L f/2.8 | 24-105L f/4IS | 100-400L f/4.5-5.6IS | 17-55 f/2.8IS | 50 f/1.8 | 28-105 f/3.5-4.5 | 4x Godox AD360
Apr 28, 2015 16:36 | #5 I would turn the IS off. For Micro Adjusting anything that might interfere should be disabled. Life is for living, cameras are to capture it (one day I will learn how!).
elliott44k Member 30 posts Likes: 1 Joined Sep 2010 More info | May 09, 2015 12:26 | #6 Permanent banI would also turn it off.
May 10, 2015 21:38 | #7 Thanks everyone. I'm going to adjust it with the is off.
eddieb1 Senior Member 986 posts Likes: 227 Joined Apr 2013 Location: Oregon More info | May 11, 2015 07:20 | #8 troyhattemer wrote in post #17551303 Thanks everyone. I'm going to adjust it with the is off. Or, if you have the time, why not test with IS on and off and report results.
digitalparadise Awaiting the title ferry... More info Post edited over 8 years ago by digital paradise. (2 edits in all) | May 11, 2015 08:41 | #9 First generation IS like my 300L F4 iS you need to turn it off. Second generation like my old 24-105 the IS deactivated when there was no motion assuming it was on a tripod. Personally I would shut it off for something this precise, just to be sure. Image Editing OK
digitalparadise Awaiting the title ferry... More info | May 11, 2015 08:52 | #10 I don't think I mentioned that Canon "USA" on two separate occasions told me MFA was for emergencies and I'm all for tightening up correctly calibrated equipment. Correctly meaning within manufacturing tolerances. Image Editing OK
| Latest registered member is semonsters 1472 guests, 130 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
