FORUMS General Gear Talk Data Storage, Memory Cards & Backup
Thread started 28 Apr 2015 (Tuesday) 00:10
This probably sounds like a stupid question but has anyone experienced this
MichaelLynn
Joined Feb 2013
Apr 28, 2015 00:10 |  #1
I have a MAC Book Pro Retina and The USB Cable I connect my my hard drive with always seems to fall out while working on my lap. I would think they would be more snug. Anyone else have this problem? It's happened with several cords in both ports. I fear a drive getting corrupted if this isn't ejected properly.
Do they make a lock style adapter to prevent this from happening pre-maturely?
Michael Lynn JR.
www.mljlive.com (external link)
Trvlr323
Apr 28, 2015 00:50 |  #2
Can't say I've ever had that happen. The drive end of the cable used to come out all the time on my older WD portables and it did cause me data corruption on one occasion.
Sometimes not taking a photograph can be as problematic as taking one. - Alex Webb
joeseph
"smells like turd"
Gallery: 263 photos
Joined Jan 2004
Apr 28, 2015 03:52 |  #3
duct tape fixes that sort of issue (I did this fix to a photographers laptop network cable during a recent Cricket World Cup game...)
TF posting: here :-)
Benitoite
Gallery: 438 photos
Joined Jan 2015
Apr 28, 2015 04:09 |  #4
USB specs allow a loose tolerance for the cable connectors, perhaps you're cable just runs loose compared with apple's socket?
Luckless
Joined Mar 2012
May 01, 2015 09:39 |  #5
Were all the cables you tried older ones? They can become damaged or worn over time, as can the ports. It is possible that the cable connectors were all used on a very snug fitting port in another computer, causing them to deform slightly, and then not fit as snuggly in your macbook.
But I do find the ports on my MacBook were somewhat loose fitting compared to other systems I've had over the years.
Canon EOS 7D | EF 28 f/1.8 | EF 85 f/1.8 | EF 70-200 f/4L | EF-S 17-55 | Sigma 150-500
Flickr: Real-Luckless (external link)
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
May 01, 2015 09:57 |  #6
FYI if you use Gaf tape, (gaffers tape) as opposed to duct tape, it will leave no residue. Gaf tape is designed to be used with electronics, and to be removed. Duct tape is designed to be permanent, and used on metal.
http://www.bhphotovide​o.com …raphy/Ntt/gaffe​r+tape/N/0 (external link)
CDS' HOT LINKS
1,708 views & 1 like for this thread, 6 members have posted to it.
1331 guests, 169 members online
