Thread started 01 May 2015 (Friday) 02:22
Just got my 70-200 2.8 v2
fordmondeo
I was Soupdragon in a former life.
May 01, 2015 02:22 |  #1
Just got my 70-200 and on the whole it lives up to expectations.
I do have a couple of questions for seasoned users.
(a) It appears that sharpness declines (with my copy) after 170mm and on to 200mm. I'm not saying the images are soft but noticeably not as crisp.
(b) The I.S. works well at low shutter speeds (sub 1/30) although it never seems perfect but, at higher shutter speeds it actually seems to degrade the image. Granted I should probably switch I.S. off after about 1/400 but is this normal?
Thanks in advance for any advice.
Vaginator9000
Talley
Talley Whacker
Gallery: 46 photos
Joined Dec 2011
May 01, 2015 12:42 |  #2
I mostly leave the IS on... you could just have a fluke of a copy. sometimes though you will get some kinda wierdness going on with IS on and shutters in the 2000+ range.
A7rIII | A7III | 12-24 F4 | 16-35 GM | 28-75 2.8 | 100-400 GM | 12mm 2.8 Fisheye | 35mm 2.8 | 85mm 1.8 | 35A | 85A | 200mm L F2 IS | MC-11
My Gear Archive
ejenner
Gallery: 98 photos
Joined Nov 2011
May 02, 2015 17:21 |  #3
I tested one of these lenses last week and found that as with the 70-200 f4 IS, at 200mm wide open and close distances (near MFD) it is definitely softer. I can't say I noticed a substantial difference between 150 and 200mm at longer distances though.
Edward Jenner
5DIV, M6, GX1 II, Sig15mm FE, 16-35 F4,TS-E 17, TS-E 24, 35 f2 IS, M11-22, M18-150 ,24-105, T45 1.8VC, 70-200 f4 IS, 70-200 2.8 vII, Sig 85 1.4, 100L, 135L, 400DOII.
http://www.flickr.com/​photos/48305795@N03/ (external link)
https://www.facebook.c​om/edward.jenner.372/p​hotos (external link)
basketballfreak6
May 02, 2015 18:58 |  #4
ejenner wrote in post #17540901 (external link)
exactly that
thought my copy was dud when I first got it, near or at MFD sharpness noticeably declines as you move away from the image centre, turns out it's just the way the lens is (confirmed with a few other copies amongst friend and a forum member)
funny it's not something that's mentioned when you read reviews, granted it's not often you'll be using the lens in that circumstance but only saw one working photog who did a review on the lens noticed it and brought it up
I don't notice degradation throughout longer focal lengths either, perhaps lens is actually misfocusing just a tiny bit that's not being picked up at shorter focal lengths due to bigger dof?
https://www.tonyliupho​tography.com.au/ (external link)
https://www.instagram.​com/tonyliuphotography​/ (external link)
R6, M6II, modified 77D, 16-35L f/4 IS, 24-70L II f/2.8, 70-200L IS II f/2.8, S150-600 f/5-6.3 C, S14 f/1.8 ART, S50 f/1.4 ART, S135 f/1.8 ART, 100L IS Macro f/2.8
GregDunn
Joined Mar 2013
May 02, 2015 20:26 |  #5
Have you performed a micro-focus adjust on the lens? Most lenses tend to exhibit a trend toward the focal length extremes wherein they don't focus at the same point as in the middle. Part of that is optical and part is mechanical; in either case, MFA might be the answer.
Canon 1Dx | 5D3 | 7D2 | 6D | 70-200L f/2.8IS | 70-200L f/4 | 24-70L f/2.8 | 24-105L f/4IS | 100-400L f/4.5-5.6IS | 17-55 f/2.8IS | 50 f/1.8 | 28-105 f/3.5-4.5 | 4x Godox AD360
fordmondeo
May 03, 2015 00:32 |  #6
I'm thinking mfd might help a bit but I find it difficult on long lenses due to my crappy tripod.
Vaginator9000
dodgyexposure
Gallery: 14 photos
Joined Jul 2012
May 03, 2015 18:59 as a reply to  @ fordmondeo's post |  #7
Try the Dot-Tune method (http://www.fredmiranda​.com/forum/topic/11872​47) (external link), it's less dependent on tripod stability than taking images and comparing sharpness.
Cheers, Damien
fordmondeo
May 04, 2015 03:17 |  #8
Having played some more I'm begining to think most of the problems are my own fault.
I am surprised at how thin the DOF is at 200mm 2.8 and now think me swaying or subject motion has more to do with non focused images than calibration errors.
I do a lot of wandering around with my 85mm at 1.2 and assumed 2.8 would give considerably more depth.
I may have got that wrong.
Can anyone recommend the best AF setting for subjects that most likely will move?
I have it set to one shot at the moment.
Vaginator9000
freestylee30
Gallery: 164 photos
May 05, 2015 16:30 |  #9
fordmondeo wrote in post #17542624 (external link)
Seems like AI Servo would be the answer to that?
Brandon | zenfolio (external link)| ♥ feedback ♥
Eternal Blue Forever Green
Image Editing OK
CANON 5DIV 50 f/1.8 85 f/1.8 135 f/2L 70-200 f/2.8L IS II
ROKINON 14 f/2.8 | TAMRON 15-30 f/2.8 VC 24-70 f/2.8 VC | SIGMA 35 f/1.4 Art |
fordmondeo
May 07, 2015 06:39 as a reply to  @ freestylee30's post |  #10
I'll give that a go then.
Vaginator9000
2,705 views & 0 likes for this thread, 7 members have posted to it and it is followed by 4 members.
1454 guests, 128 members online
