Does the minimum shutter speed settings not apply with a manual flash? I have ttl flashes and the sync speed limits respond but if I use my manual flash, it does not. I realize this is probably a pretty basic question.
NewCreation Goldmember More info | May 01, 2015 12:09 | #1 Does the minimum shutter speed settings not apply with a manual flash? I have ttl flashes and the sync speed limits respond but if I use my manual flash, it does not. I realize this is probably a pretty basic question. My name is Brenda ~Saved by grace, walking by faith
LeftHandedBrisket Combating camera shame since 1977... More info | May 01, 2015 12:50 | #2 the camera doesn't know there is a flash on it so it doesn't know to limit the SS. PSA: The above post may contain sarcasm, reply at your own risk | Not in gear database: Auto Sears 50mm 2.0 / 3x CL-360, Nikon SB-28, SunPak auto 322 D, Minolta 20
OceanRipple* Senior Member 842 posts Likes: 175 Joined Dec 2014 More info | May 01, 2015 13:16 | #3 . . . . . . . . and - the max sync speed limit still applies, you just have to remember that yourself when using M flash or M triggers. ? 1/160th with a 6D.
May 01, 2015 13:20 | #4 Left Handed Brisket wrote in post #17539796 the camera doesn't know there is a flash on it so it doesn't know to limit the SS. Thanks. That is what I found out. Manual setting with manual flash will have to be the plan. I do have ttl flashes, as well, but it's good to fiddle with the back up stuff once in a while just to be familiar. I mostly use the manual flashes off-camera in manual any way. OceanRipple* wrote in post #17539823 . . . . . . . . and - the max sync speed limit still applies, you just have to remember that yourself when using M flash or M triggers. ? 1/160th with a 6D. Thanks for chiming in. My frustration was that the shutter was too slow. I'll stick with manual for manual flash. I think it's technically 1/180 on a 6d, which you don't see with 1/3 exposure increments set. My name is Brenda ~Saved by grace, walking by faith
| Latest registered member is Niagara Wedding Photographer 875 guests, 162 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
