When I ordered a 17mm TS-E lens, I wondered about the use of filters--circ-pols, NDs, grad-NDs--and was pointed at the Fotodiox system. Here's an advanced kit; there are others. https://www.fotodioxpro.com …rc-essentials-nd-kit.html![]()
Called the WonderPana FreeArc system, it's based on a large adapter ring with versions to fit many ultrawide-angle lenses with bulbous front elements that preclude the use of normal screw-on filters. I knew nothing of these kinds of things, and since I just spent a bunch on a kit, I thought we would benefit from my jumping in with both feet.
The adapter ring fits on the front bayonets that hold the 17's lens cap.
IMAGE LINK: http://s89.photobucket.com …200w_zpsmu2n707u.jpg.html
The ring locks onto these and one now has a very large--almost 6" diameter--filter ring on the lens.
IMAGE LINK: http://s89.photobucket.com …200w_zpsr1oo99xn.jpg.html
Here with ring-and-lens cap.
IMAGE LINK: http://s89.photobucket.com …200w_zps6uikolkv.jpg.html
IMAGE LINK: http://s89.photobucket.com …200w_zpsj1imaki5.jpg.html
The four-stop ND:
IMAGE LINK: http://s89.photobucket.com …200w_zpskm6awfhe.jpg.html
If screw-on filters are all you wish to use on your 17, you're set. If you wish to use slide-in filters, please read Part two.
Continued in Part Two...
https://photography-on-the.net …showthread.php?p=17540820
