Thread started 05 May 2015 (Tuesday) 04:39
Cleaning external viewfinder
Frodge
Joined Nov 2012
May 05, 2015 04:39 |  #1
How do you guys clean the plastic external viewfinder of dust-specks without scratching, leaving swirl marks or making more of a mess?
“It's kind of fun to do the impossible.” - Walt Disney.
Equipment: Tokina 12-24mm, Canon 40mm 2.8, Tamron 17-50 2.8 XR Di, Canon 18-55mm, Canon 50mm 1.8, Tamron 70-300VC / T3I and 60D
apersson850
Obviously it's a good thing
Gallery: 35 photos
May 05, 2015 04:58 |  #2
External viewfinder, what's that? The eyepiece? Or are you refering to the rear LCD?
Anders
Frodge
Joined Nov 2012
May 05, 2015 05:04 as a reply to  @ apersson850's post |  #3
Where you put your eye.
iroctd
Joined Aug 2013
May 05, 2015 06:13 |  #4
If the rocket air doesn't remedy it then I use a very poofy paint brush (looks similar to one of those ladies make-up brushes, available at arts & craft stores) that results in a very gentle and light brushing action. This brush is also good for removing the dust from bodies and lenses plus those rubber focusing and zoom rings that snag all kinds of stuff.
-Feedback-
MakisM1
Gallery: 50 photos
Joined Dec 2011
Post edited over 8 years ago by MakisM1.
May 05, 2015 07:14 |  #5
Strange! I just did both of my cameras yesterday.
Remove the rubber eyecup.
Blast with Rocket Blower until you are tired.
Remove the rest with q-tip style thingie that comes with lens cleaners and lens cleaning liquid. Repeat until fed up.
Leave the rest there.
Under no circumstances look at the viewfinder while pointing at a bright light with no lens on. You have been warned!:-D
I removed about 95 percent of the crud (a lot of sticky stuff) in 20 minutes. It took me 2 1/2 hours to find the eyecup!vmad
Gerry
Left ­ Handed ­ Brisket
Gallery: 15 photos
Joined Jun 2011
May 05, 2015 07:45 |  #6
MakisM1 wrote in post #17544219 (external link)
^ two very important things to keep in mind!
after taking it off and replacing with the light blocker thing, I've gone days without the rubber eye cup due to putting it "somewhere i couldn't forget".
but i find that if i don't wear my dollar store reading glasses i can't see the filth and muck on the eyepiece. ignorance is bliss.
5280Pics
Gallery: 522 photos
May 06, 2015 16:05 |  #7
Rocket blower, and lens pen, for me.
Taking pics, and peeping pixels!
apersson850
Gallery: 35 photos
May 07, 2015 03:43 |  #8
I have a correction lens mounted on top of the eyepiece. Keeps the dirt away from the eyepiece. The correction lens can of course be removed for cleaning.
Anders
Tapeman
Sliced Bread
Joined Jan 2004
May 07, 2015 08:55 |  #9
Q tip & cleaning fluid.
Canon G1X II, 1D MKIV, 5DSR, 5DIV, 5D MKII, 16-35/2.8L II, 24-70/2.8L II, 70-200/2.8L IS II, IS, 100-400/4.5-5.6 L IS II, 500/4 L IS II, 24-105/4 IS, 50/2.5 macro, 1.4x MKII, 1.4X MKIII, 2X MKIII,580EX II, 550EXs(2), ST-E2.
Gitzo 1228, 1275, 1558, Lensbaby 3G. Epson 3880, Bags that match my shoes.:)
melcat
Joined Nov 2010
May 09, 2015 03:03 |  #10
What makes you think it's plastic? The viewfinder is an optical system.
Clean it as you would the surface of a multicoated lens. I use a rocket blower, followed by lens solution on microfibre cloth if necessary. I've used a blunt wooden cooking skewer behind the cloth to push it into the edges and corners.
Tom ­ Reichner
"That's what I do."
Gallery: 213 photos
Location: from Pennsylvania, USA, now in Washington state, USA, road trip back and forth a lot
Post edited over 8 years ago by Tom Reichner.
May 09, 2015 10:52 |  #11
I've never heard it called an external viewfinder before.
I clean the viewfinder by taking my glove off and putting the tip of my pinky finger on the viewfinder glass. I then smear my pinky fingertip across the surface of the glass. This removes the heavy condensation that forms when I accidentally breathe on the viewfinder. I would leave the glove on for this, except that the finger with the glove on it is too big to get down onto the surface of the glass, hence I take the glove off.
I've never seen any reason to clean anything else off of it, as dust or grease on it does not bother me in the least. Heck, I don't even see or notice that stuff.
elliott44k
May 09, 2015 12:22 |  #12
Blower :)
serrow
Joined May 2015
May 10, 2015 22:49 as a reply to  @ Frodge's post |  #13
i use a bellows... blows everything across the room
3,137 views & 1 like for this thread, 11 members have posted to it and it is followed by 2 members.
1294 guests, 135 members online
