Thread started 06 May 2015 (Wednesday) 12:46
Cleaning bowl reflectors
Alveric
Gallery: 38 photos
Post edited over 8 years ago by Alveric. (2 edits in all)
May 06, 2015 12:46 |  #1
What do you guys use to clean/wipe your reflectors so as not to damage the finish?
This one reflector looks like it was cleaned before I purchased it, and under the light of the modeling light you can see all the traces of the previous wiping over its surface. I want to get that off.
Thanks.
Left ­ Handed ­ Brisket
Gallery: 15 photos
Joined Jun 2011
May 06, 2015 13:13 |  #2
distilled water would be the first place to start.
likely the marks left are deposits from whatever cleaner was used. Distilled water will leave no residue. If they cannot be reconstituted and removed, i would spray windex on to a rag and give it a shot.
spraying on a rag essentially dilutes it to the point it should leave no residue.
Alveric
Gallery: 38 photos
May 06, 2015 13:35 |  #3
Alright. I'll try to grab some distilled water at Shopper's. I do have Windex, but was reluctant to use it, as it's got chemicals.
Thanks, Brisket.
Gallery: 15 photos
Joined Jun 2011
May 06, 2015 14:04 |  #4
i'm guessing the distilled water will do the trick.
btw, my advice is from taking care of monitors with non reflective coatings. The distilled water certainly won't hurt anything and will likely solve the problem. Windex is basically watered down ammonia and if it's okay for coated glass it's gotta be okay for coated metal.
oh, and spray the windex onto the same rag with the distilled water, is what i meant. the windex will add just a touch more cleaning power. Tightly woven fabric like a baby diaper is the best bet, soft yet strong with no fibers left behind.
953 views & 0 likes for this thread, 2 members have posted to it.
1650 guests, 136 members online
