I remember reading a thread about this but I can't find it at all! Anybody uses these speedrings? how are they? any pictures of the mounted flash?
Thanks!
Daniel.E Member 177 posts Likes: 5 Joined Feb 2012 Location: Virginia Beach, VA More info | May 12, 2015 15:51 | #1 I remember reading a thread about this but I can't find it at all! Anybody uses these speedrings? how are they? any pictures of the mounted flash? 5D2 | 50mm f1.4 USM | 85mm f1.8 USM | 135mm f/2L
May 20, 2015 21:28 | #2 Nobody has used those? 5D2 | 50mm f1.4 USM | 85mm f1.8 USM | 135mm f/2L
windpig Chopped liver More info | May 21, 2015 06:09 | #3 What modifier are you wanting to mount? Would you like to buy a vowel?
May 21, 2015 09:58 | #4 The 39" deep octa. 5D2 | 50mm f1.4 USM | 85mm f1.8 USM | 135mm f/2L
calico Member 67 posts Likes: 11 Joined Jan 2015 Location: Toronto More info | It's tempting since it's on sale at B&H. I've had it sitting in my cart for a while. Curious to try it with Einstein.
May 21, 2015 11:22 | #6 Me too! but I have it in my Adorama cart for awhile. 5D2 | 50mm f1.4 USM | 85mm f1.8 USM | 135mm f/2L
windpig Chopped liver More info | May 21, 2015 15:48 | #7 I've got the 39DO. Personally I'd go with a Fotodiox EZ Pro (which I also have). You can order the EZ Pro with the speed ring you need. Using the inner diffuser only will give you a similar look as the 39DO with inner diffuser only, plus it's more bomb proof and you have a grid as an option. Would you like to buy a vowel?
May 21, 2015 15:51 | #8 Thanks! I have the Fotodiox too but broke. I was able to fix it somehow but got me thinking of getting the Elinchrom. I'll stick with it 5D2 | 50mm f1.4 USM | 85mm f1.8 USM | 135mm f/2L
calico Member 67 posts Likes: 11 Joined Jan 2015 Location: Toronto More info | I might buy that speedring today. Do you guys have grid for 39DO? I'm thinking of getting this one and then figure out how to attach it. http://www.bhphotovideo.com …c_grid_for_octagonal.html
abbadon31 Goldmember More info | May 22, 2015 11:58 | #10 calico wrote in post #17566781 I might buy that speedring today. Do you guys have grid for 39DO? I'm thinking of getting this one and then figure out how to attach it. http://www.bhphotovideo.com …c_grid_for_octagonal.html That will not fit the Elinchrom 39DO I AM SHOM
calico Member 67 posts Likes: 11 Joined Jan 2015 Location: Toronto More info | Thanks Scott but simple solution like this would work I think. Image hosted by forum (728895) © calico [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff.
simonbarker Senior Member 253 posts Likes: 65 Joined Mar 2009 More info | May 22, 2015 12:28 | #12 calico wrote in post #17566899 Thanks Scott but simple solution like this would work I think. It won't work or at least it won't work well, the front diffuser is flush with the front so you'd have deform the shape of one to clip a grid in.
calico Member 67 posts Likes: 11 Joined Jan 2015 Location: Toronto More info | Thanks Simon. I see how that can be a problem if used with front diffuser. I rarely use front diffuser with 39DO and more often than not I just use translucent deflector. Lighttools is out of the question and at this point in time I can't justify Honeygrids either.
Whortleberry Goldmember 1,719 posts Likes: 53 Joined Dec 2011 Location: Yorkshire, England More info | May 22, 2015 16:44 | #14 Actually it's not a problem at all. I took a spare hooded diffuser for my 100cm / 39" DO, stitched 2" wide Velcro (don't try using the self-adhesive Velcro) to the skirt adjacent to the diffuser face and then applied a 90cm Jinbei Octa grid to this. Hence I can now use the Octa with flat face diffuser, recessed diffuser solo or recessed diffuser with grid as appropriate. The only thing I can't do is grid with no front diffuser - but I never planned on doing this anyway. Phil ǁ Kershaw Soho Reflex: 4¼" Ross Xpres, 6½" Aldis, Super XX/ABC Pyro in 24 DDS, HP3/Meritol Metol in RFH, Johnson 'Scales' brand flash powder. Kodak Duo Six-20/Verichrome Pan. Other odd bits over the decades, simply to get the job done - not merely to polish and brag about cos I'm too mean to buy the polish!
| Latest registered member is RawBytes 1577 guests, 161 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
