Thread started 12 May 2015 (Tuesday) 18:59
A second firmware update for Tamron 150-600 Canon mount
pknight
Gallery: 39 photos
Joined Feb 2006
May 12, 2015 18:59 |  #1
I have had my Tamron 150-600 for 10 months (62 months left on my warranty! :-)), and have been very pleased. I have not had the focus issues that others have reported, although my use of AI Servo has been limited. It does track a moving subject well. However, the other day I happened to notice that I was indeed experiencing one of the issues that some 150-600 users have described in AI Servo mode. That is, if I achieve focus on a subject at either a far distance or near distance, when I move the camera to a near or far subject (respectively), it does not change focus. Not good, so I emailed Tamron support and described my problem. Below is part of the response I received:
"Thank you for contacting Tamron. I'm sorry to hear about the issue you are having with your 150-600 lens. We do have an update for this lens that should help with autofocus all around. This update may be able to help with the problems you are having. It's also possible that there is something else wrong with the lens but we could check this as well. In addition we released another update recently that will improve autofocus functionality when panning with a subject. If you would like to send it in for the update, please fill out the attached service form, and include a copy of your proof of purchase OR your warranty confirmation number. "
So, it appears that the AF-while-panning issue, which was not addressed in the initial firmware update, has now been addressed in a new update. My lens is going back tomorrow, and I will report on its behavior when I get it back.
Digital EOS 90D Canon: EF 50mm f/1.8 II, EF 50mm f/2.5 Compact Macro, Life-Size Converter EF Tamron: SP 17-50mm f/2.8 DiII, 18-400mm f/3.5-6.3 DiII VC HLD, SP 150-600 f/5-6.3 Di VC USD G2, SP 70-200 f/2.8 Di VC USD, 10-24mm f/3.5-4.5 DiII VC HLD Sigma: 30mm f/1.4 DC Art Rokinon: 8mm f/3.5 AS IF UMC
BigAl007
Gallery: 556 photos
May 12, 2015 19:03 |  #2
Fixing the lack of VC at slow shutter speeds would really help the Tamron, especially now that the Sigma C is available at nearly the same price which has a panning mode for the OS.
Alan
LV ­ Moose
Moose gets blamed for everything.
Gallery: 223 photos
Post edited over 8 years ago by LV Moose.
May 12, 2015 19:04 |  #3
Nuts.
Really hate sending things back. But now that I've been informed, I'll always wonder if I could have benefitted from it, if I don't.
You suck
;-)a
Moose
Gear... Flickr (external link)...Flickr 2 (external link)...
Macro (external link)...Hummingbirds (external link)
Aircraft (external link)
pknight
Gallery: 39 photos
Joined Feb 2006
May 12, 2015 19:21 |  #4
LV Moose wrote in post #17554038 (external link)
Nuts.
You suck
;-)a
:-P
We aim to please!
pknight
Gallery: 39 photos
Joined Feb 2006
Post edited over 8 years ago by pknight.
May 12, 2015 19:27 |  #5
BigAl007 wrote in post #17554037 (external link)
Alan
Agreed. Tamron claims that their VC technology does not require a panning mode, except that it didn't work out for them on this lens. I hope that this update brings the 150-600 into line with their other lenses.
BigAl007
Gallery: 556 photos
May 13, 2015 08:19 |  #6
pknight wrote in post #17554054 (external link)
I know that fixing the VC would be good for Tamron, I do not think that it will be possible with a firmware fix. From the lengthy telephone conversation I had with a Rep from the Tamron UK importers it is a hardware issue. The auto detecting system in the 70-200/300 lenses apparently cannot cope with the extreme magnification at 600mm, so that had to use a completely different system to those other lenses. This conversation was pre the Sigma 150-600 announcement, so at that time they had no competition. The Tamron is still a very good lens, but the lack of VC while panning at shutter speeds below around 1/500 is a bit of a killer for those of us who need that option. It's not such a problem for the birders though, as for BiF it seems that the higher the shutter speed the better.
Alan
pknight
Gallery: 39 photos
Joined Feb 2006
May 13, 2015 09:28 as a reply to  @ BigAl007's post |  #7
Well, I know that you need those slow shutter speeds for plane shots, so I understand. However, the proof is in the pudding, and I will try to find something to pan using a slow shutter speed once I get the lens back. If I am interpreting your message correctly, the rep told you that the 150-600 had to have a different VC system than what is found in the shorter Tamron lenses. That might explain, due to a lack of experience with the new system, why there are problems, but I don't see why new programming for the new system could not, theoretically, make it work better. Of course, the message I received did not talk about the VC system at all, but only mentioned improved autofocus functionality when panning. Whether that means they are addressing the VC operation is not clear.
I will remain skeptical about everything until I get the lens back. I'm not sure what difference the update will make, and I am have heard and seen too many false statements from retailers and the like (who are just one step removed from importers ;-)a) to put a lot of stock in what they say. I will report back when I put the lens through its paces, probably not before the end of next week.
4,374 views & 0 likes for this thread, 3 members have posted to it and it is followed by 4 members.
1597 guests, 140 members online
