What's wrong here? It was working fine the last time I opened the photo..
It's the raw file
TheCor Senior Member 428 posts Likes: 617 Joined Sep 2008 More info | May 13, 2015 19:25 | #1 What's wrong here? It was working fine the last time I opened the photo.. 6D | 70-200 f2.8 is ii | 24-105 f4L | 50mm f1.8 | 40D | 17-55 IS f2.8 | Canon 580EXII | Yongnuo 565EX | YN622C's
Trvlr323 Goldmember 3,318 posts Likes: 1091 Joined Apr 2007 More info Post edited over 8 years ago by Trvlr323. | May 13, 2015 19:37 | #2 Your title references import but you mention opening the file previously. Do you mean that this file was previously imported and you could see it OK or you are re-importing this file and it is now displaying like this? Sometimes not taking a photograph can be as problematic as taking one. - Alex Webb
TheCor THREAD STARTER Senior Member 428 posts Likes: 617 Joined Sep 2008 More info Post edited over 8 years ago by TheCor. | May 13, 2015 19:43 | #3 I was going to work on it then this happened. 6D | 70-200 f2.8 is ii | 24-105 f4L | 50mm f1.8 | 40D | 17-55 IS f2.8 | Canon 580EXII | Yongnuo 565EX | YN622C's
DGStinner Goldmember More info | May 13, 2015 20:11 | #4 My thought is it's a corrupt file.
Trvlr323 Goldmember 3,318 posts Likes: 1091 Joined Apr 2007 More info | May 13, 2015 20:13 | #5 Well, it is definitely corrupt. I seriously doubt Lightroom is responsible but it may have happened on the card or somehow during import. How are the other files from this import? Sometimes not taking a photograph can be as problematic as taking one. - Alex Webb
May 13, 2015 20:13 | #6 Yeah, well it's weird because I worked on it like 3 days ago and it was fine. 6D | 70-200 f2.8 is ii | 24-105 f4L | 50mm f1.8 | 40D | 17-55 IS f2.8 | Canon 580EXII | Yongnuo 565EX | YN622C's
DGStinner Goldmember More info | Do you have a backup copy that you can check and, if good, overwrite the corrupt one?
Yeah still had the files on my camera, so I overwrote it and it's working fine. 6D | 70-200 f2.8 is ii | 24-105 f4L | 50mm f1.8 | 40D | 17-55 IS f2.8 | Canon 580EXII | Yongnuo 565EX | YN622C's
DGStinner Goldmember More info | May 13, 2015 20:21 | #9 TheCor wrote in post #17555440 But why all of a sudden it became corrupt within LR? It was corrupt on the hard drive, possibly because of a bad sector. Lr just read the file as it was.
May 13, 2015 20:27 | #10 It's a brand new computer, HDD and everything.. Grrr 6D | 70-200 f2.8 is ii | 24-105 f4L | 50mm f1.8 | 40D | 17-55 IS f2.8 | Canon 580EXII | Yongnuo 565EX | YN622C's
Trvlr323 Goldmember 3,318 posts Likes: 1091 Joined Apr 2007 More info | May 13, 2015 20:32 | #11 I have to agree that the corruption occurred somewhere outside LR. I just can't see LR causing this kind of damage. Sometimes not taking a photograph can be as problematic as taking one. - Alex Webb
DanMarchant Do people actually believe in the Title Fairy? 5,634 posts Gallery: 19 photos Likes: 2056 Joined Oct 2011 Location: Where I'm from is unimportant, it's where I'm going that counts. More info | May 14, 2015 00:34 | #12 Other than when the file is initially imported Lightroom doesn't write to or edit RAW files, so it can't corrupt them. Even when importing the actual copy/write process is handled by the OS. Dan Marchant
DaveR. Senior Member 275 posts Likes: 5 Joined Jan 2008 Location: Pacific Northwest More info | May 14, 2015 07:46 | #13 TheCor wrote in post #17555455 It's a brand new computer, HDD and everything.. Grrr Brand new of anything can have flaws. I'm not saying that is the case here but the fact is just because it's new doesn't mean it's 100% right. Hopefully this will not occur again but if it did I for one would be trying a different card reader assuming that is what you have been using. Good luck in tracking down the culprit.
May 14, 2015 08:31 | #14 I'll run check disk tonight. 6D | 70-200 f2.8 is ii | 24-105 f4L | 50mm f1.8 | 40D | 17-55 IS f2.8 | Canon 580EXII | Yongnuo 565EX | YN622C's
May 14, 2015 19:58 | #15 I think I found the problem, the SM Bus driver wasn't installed properly which I think was my SSD. 6D | 70-200 f2.8 is ii | 24-105 f4L | 50mm f1.8 | 40D | 17-55 IS f2.8 | Canon 580EXII | Yongnuo 565EX | YN622C's
| Latest registered member is Monkeytoes 1384 guests, 179 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
