Thread started 16 May 2015 (Saturday) 10:23
SSD in Laptop, spinning disk for clone?
LARAB
May 16, 2015 10:23 |  #1
I am using a Samsung 840 EVO in my laptop, and a WD Blue for a periodic clone. With the recent issues surrounding the 840 I downloaded Samsung's disk utility and configured based on those recommendations. It occurred to me me that those system configurations may cause problems using a non-ssd as my bootable clone.
I am not tech-savy enough to know, anyone have experience in these matters?
-Brian
bk2life
Gallery: 18 photos
Joined Nov 2010
May 16, 2015 10:44 |  #2
yes.
keep a back-up image (copy) of your computer on a HD.
use the SSD in the laptop
-james
5Diii|7D|Nifty 50|Canon 17-55mm-2.8|Canon 70-200L 2.8 IS ii|2x 600EX-RT|ST-E3-RT|CS6
LARAB
May 16, 2015 11:54 |  #3
I am already running the drives as mentioned - it was the dis-similarity of the drives and configuration based on one and not the other that concerned me. In the event that the SSD fails and I install the spinning disk, will the settings for the SSD (now on the spinning disk) cause problems? I assume I could disable the Samsung disk utility after installing the WD.
Time to swap drives and find out...
mike_d
May 16, 2015 12:01 |  #4
It'll be fine. The Samsung Magician just won't find any Samsung SSDs.
Kolor-Pikker
May 16, 2015 12:06 |  #5
You can probably swap them no problem, but the Samsung related utilities won't work anymore. Otherwise, both drives use the same port and protocol, so I doubt the computer itself would get confused. I'm sure it'll disable TRIM automatically, but you can check.
5DmkII | 24-70 f/2.8L II | Pentax 645Z | 55/2.8 SDM | 120/4 Macro | 150/2.8 IF
I acquired an expensive camera so I can hang out in forums, annoy wedding photographers during formals and look down on P&S users... all the while telling people it's the photographer, not the camera.
tim
Light Bringer
May 17, 2015 03:55 |  #6
You don't need to clone it to another disk, use Macrium Reflect Free (external link) to keep an image on a spinning drive. Of course if you have a huge SSD with things on it like catalog, cache, and heaps of data the image will be huge. That's why I have one SSD for OS and programs and one for data. The OS drive is 120GB but only 40GB used, the other drive is 120GB and probably about the same used. Maybe not efficient but good for backups.
1,006 views & 1 like for this thread
Latest registered member is elkaboing
878 guests, 253 members online
