Thread started 17 May 2015 (Sunday) 22:52
Lightroom 5 - Conditional Processing?
Moonshiner
Joined Jul 2013
May 17, 2015 22:52 |  #1
So, I did look around the internet for information, but I was without success. I am not certain how else to describe what I am looking to do other than what the title says. Is there a way that I can write "processing expressions" that will do certain tasks ONLY if the criteria is met?
Basic types of examples would be something like:
If IS0 >= 1600 Then Boost Saturation + 5
If Lens Make = Sigma AND Lens Model = Sigma 30mm 1.4 Then Enable Remove Chromatic Aberration Amount + 5
I am fairly new to Lightroom so I may not have all the vernacular down just yet... But if someone can point in me the right direction, I'd appreciate it...
Thanks!
Trvlr323
May 17, 2015 22:57 |  #2
Might be an interesting feature but we're out of luck. May exist in some plugin but not one I'm aware of.
Sometimes not taking a photograph can be as problematic as taking one. - Alex Webb
Nogo
POTN record for # of posts during "Permanent Ban"
Gallery: 17 photos
Joined Dec 2013
Post edited over 8 years ago by Nogo.
May 17, 2015 23:08 |  #3
There may be plugins to do just what you want. I don't know. As for making adjustments to the lens, that can be done with the Filter by Camera Info. Go to grid mode in the Library Module and click on Filters > Camera Info > Metadata. When you do this it will allow you to choose all photos taken with every lens and if you want, you can also select by focal length for those lenses. After you filter out all the other photos, then do whatever function you wish to one of those photos in the develop module. Then select all photos and sync the settings.
Philip
hollis_f
May 18, 2015 07:40 |  #4
You can save sets of default processing parameters that get applied automagically. You can have different parameters for different ISO values and/or camera models.But that, I'm fairly sure, is it.
Frank Hollis - Retired mass spectroscopist
Give a man a fish and he'll eat for a day. Teach a man to fish and he'll complain about the withdrawal of his free fish entitlement.
Gear Website (external link)
Moonshiner
Joined Jul 2013
May 18, 2015 08:25 |  #5
Thanks all...
Your responses confirm that there is a lack of full automation... Yes, there is automation via presets which I have to manually sort/filter and then apply. That is a manual effort. I will look via plugins, but I am not hopeful. "Intelligent" processing based on historical actions or defined actions would be great from my "beginners" vantage. Some of the more seasoned people may or may not like it as much.
Thanks again!
BigAl007
Gallery: 556 photos
May 18, 2015 08:49 |  #6
Yes it is possible to save defaults by camera body and/or ISO, but not by lens. It would though be quite easy to make presets for the the lenses, and it is very easy to select images by lens settings, as has been described above. when saving a preset you have the ability to select only those settings that you want to be changed, leaving the others as they are. If you select a group of images, although you only see the top image, if you have AutoSync enabled, the editing steps are applied to every image that is selected. You also then get to see each step in each images history stack, rather than seeing a whole group of edits applied at once as you get with manual syncing.
Alan
kirkt
May 18, 2015 10:14 |  #7
On the Luminous Landscape forum, around the time that Adobe was converting everything to a subscription-based model and people were thinking about the future of Photoshop, there was a thread started by Jeff Schewe asking forum members what they would want the new, futuristic version of photoshop to be. Or something to that effect - the thread was called " If Thomas designed a new Photoshop for photographers now..." Thomas being Thomas Knoll.
I suggested that photoshop be redesigned to include a node-based workflow, where you essentially build workflows out of nodes to accomplish whatever processing you want - this approach could include all sorts of logic to abstract the processing pipeline to whatever level of file handling you want. It would be much more rational and interactive than the current Smart Object kludge. It is nothing new - there are several video and 3D modeling and rendering applications that already use this approach.
Hopefully Adobe will spend some time and effort on the abstract, workflow pipeline and completely redesign their essential tools to take advantage of modern input and output devices, GPU and CPU power and large digital files.
Here is the post in the thread:
http://forum.luminous-landscape.com …78240.msg628951​#msg628951 (external link)
and here is the text of my post:
I would like to see a "new" version of "photoshop" substantially change the workflow paradigm, whatever the resulting toolset is. Specifically, I think we, as image processing folks, tend to work on an image sequentially - whatever that sequence is. Open raw image > make adjustments > send to Photoshop > apply adjustment layers with masks > reduce image size > output sharpen, etc.
Whatever. The idea is, there is a sequence to the workflow and, often, portions of that sequence require revisiting, revision, branching into a new variation, etc.
I think a node-based workflow, where one can piece together these operations in a logical flow, and revisit, rearrange, preview and create variations, with a real-time preview of any and all node outputs, would be a nice paradigm shift. I would have no problem working on a "smart preview" version of an image, from raw conversion, all the way to output sharpening at final resolution, with the ability to render portions of it all along the node chain to see a 100% res sample to check my work. Once my node chain is set up and I like the preview of the resulting changes, I could render a full-res version. This is pretty standard for many render/modeling applications and video/compositing. There is no reason why 2d image workflow has to be any different.
I think that 2D image workflow could benefit from this approach as well because it would promote variation - just create a branch off of the workflow and develop it separately. It would ease automation - you can visualize your process and simply add an input node as a directory of images in front of your established chain of nodes to batch process images. It could leverage the nascent "Smart Preview" raw technology that appears to be developing for the Cloud sync and smart device editing workflow. THis node-based workflow fully preserves the "non-destructive" aspect of editing - the node-based edits are "parametric" until you finally commit to rendering them as full-res output - the original image is untouched, even if you chose to make pixel-based changes - this could be a node where a rendered proxy is part of the workflow, etc.. You could add output nodes along the way to render draft images of the stages of the edits, instead of having to save sequential PSDs to potentially have to revisit and revise. The entire creative process is archived and editable - you could have template node structures for commonly used tasks, or commonly shot lighting conditions, looks, etc. You could even save that entire node chain as ... you guessed it, a node, for use in other more complex chains - this would be like an action, but more flexible.
Of course, I would hope people could write their own nodes and third-party developers could write all sorts of "plug-ins" (nodes) or adapt currently existing products into a node-based form. I see Lightroom as a node in this paradigm.
I apologize if this has already been mentioned in this thread, I know I am not inventing anything new here. However, if there is to be a new photoshop, or yet-to-be-named image editor, I think a new workflow approach is in order and would save huge amounts of time and effort in the image processing workflow.
best - thanks jeff for starting this thread - I appreciate the chance to participate.
kirk
I believe that this will require a completely new version of Photoshop, redesigned from the ground up. I would be very impressed with Adobe if they committed the time and resources to doing this, instead of adding new, sometimes gimmicky features to the kludged together code that is Photoshop. Lightroom (ACR) would just be a NODE in the workflow, and the heavy lifting would be done in the context of Photoshop.
Anyway, one can always dream.
kirk
Kirk
1,567 views & 0 likes for this thread, 6 members have posted to it and it is followed by 3 members.
1514 guests, 131 members online
