I am new! I want to learn. You all probably have experience with both or any other software out there. If you were to pick one, which one? What is the main difference between LR and PSE? Are they meant for different types of processing? Thanks!
Tatiana99 Member 41 posts Likes: 1 Joined Apr 2015 More info | May 20, 2015 12:52 | #1 I am new! I want to learn. You all probably have experience with both or any other software out there. If you were to pick one, which one? What is the main difference between LR and PSE? Are they meant for different types of processing? Thanks!
LittlejonDsgn Goldmember 3,266 posts Likes: 905 Joined Feb 2012 Location: Sandy, Oregon More info | May 20, 2015 12:55 | #2 I do 90% of my editing in LR but the biggest thing I use LR for is managing my files. I do not believe PSE has this built in.
maverick75 Cream of the Crop More info | May 20, 2015 13:06 | #3 |
LittlejonDsgn Goldmember 3,266 posts Likes: 905 Joined Feb 2012 Location: Sandy, Oregon More info | May 20, 2015 13:10 | #4 maverick75 wrote in post #17564287 I wouldn't call lightroom an editor , it's more of a organizer/raw processor. Once you use Photoshop you'll understand why. This is very true, but depending on what you shoot and the level or editing you need to do LR might be able to do all the editing you need
gonzogolf dumb remark memorialized More info | May 20, 2015 13:13 | #5 Lightroom is increasingly useful in making certain adjustments and fixes to images, but once youve experienced the power of layers In photoshop lightroom is less satisfying.
LittlejonDsgn Goldmember 3,266 posts Likes: 905 Joined Feb 2012 Location: Sandy, Oregon More info | May 20, 2015 13:18 | #6 gonzogolf wrote in post #17564305 Lightroom is increasingly useful in making certain adjustments and fixes to images, but once youve experienced the power of layers In photoshop lightroom is less satisfying. Does PSE have layers?
May 20, 2015 13:25 | #7 Can you do layers in LR?
May 20, 2015 13:27 | #8 I started with PSE and later moved to Lightroom. The best thing that PSE will give you is layers. It's got most of the tools of PS, but unfortunately it is stripped down. For instance, it's all 8-bit. It's a cheap way to get your feet wet if you enjoy composites and post-processing. Lightroom on the other hand only has a very basic "idea" of layers, but it does work extremely well for basic photo edits. Also, everything you do is based on the original raw file so you're not losing any information in conversions. I'd recommend watching a few youtube videos on each so you can decide which one suits you best.
LittlejonDsgn Goldmember 3,266 posts Likes: 905 Joined Feb 2012 Location: Sandy, Oregon More info Post edited over 8 years ago by Littlejon Dsgn. | May 20, 2015 13:27 | #9 Tatiana99 wrote in post #17564321 Can you do layers in LR? How exactly does it help to "manage" files? LR does not have the ability to use layers.
May 20, 2015 13:29 | #10 They're different tools. You can't really make a comparison. http://www.avidchick.com
gonzogolf dumb remark memorialized More info | May 20, 2015 13:36 | #11 Littlejon Dsgn wrote in post #17564315 Does PSE have layers? Yes. There ar e fewer adjustments but its pretty capable. I have to admit little expertise with PSE, I helped a friend learn the basics using it.
May 20, 2015 13:43 | #12 Got it. Thanks guys! I thought they were similar editing tools. I'll check out Youtube. I have PSE10, I'm learning very basics of it. I was wondering if by getting LR I will duplicate. I have tons of pictures that I can't seem to find a good way to organize. I'll give LR a try!
Archibald You must be quackers! More info | May 20, 2015 13:52 | #13 I use LR for all my photo editing. Why not? It can darken and lighten images, crop, straighten horizons, dodge and burn, fix white balance, enhance colors or turn them into B/W, clone out spots, darken skies and vignette, correct lens aberrations and camera ideosyncracies, and more. Canon R5 and R7, assorted Canon lenses, Sony RX100, Pentax Spotmatic F
LVMoose Moose gets blamed for everything. More info Post edited over 8 years ago by LV Moose. | May 20, 2015 13:58 | #14 |
Nogo POTN record for # of posts during "Permanent Ban" 9,188 posts Gallery: 17 photos Likes: 685 Joined Dec 2013 Location: All Along the Natchez Trace (Clinton, MS) More info | The big difference between PSE and Lightroom is Lightroom allows you to work on all your images at once without having to load and save each and every image. If all your images need some of the same adjustments, you can adjust one image and then select all the other images and sync the setting to all the photos. Philip
| Latest registered member is icebergchick 1412 guests, 157 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
