FORUMS Post Processing, Marketing & Presenting Photos HDR Creation
Thread started 20 May 2015 (Wednesday) 20:41
When to delete bracketed exposures?
repete7
Gallery: 10 photos
Joined Nov 2010
May 20, 2015 20:41 |  #1
When photographing what seems to be a high contrast scene, I often bracket my exposures, just in case I want to use HDR later. Then, when I load them in Lightroom, sometimes the base exposure looks OK. The histogram might have a peak towards the blacks, be a little flat in the midtones, and another peak in the highlights, but the whites aren't clipped and there is decent detail in the shadows. In this case I don't see an advantage in processing with HDR. Is there something I'm missing? Is there any reason to keep the extra bracketed exposures?
Karen Flickr (external link)
Canon 6D2|Canon Eos-m|Canon ef-m 22|Samyang 14mm f/2.8|Canon 40 stm|Canon 50 f/1.8 stm|Canon FD 50mm macro|Canon Macro 100L|Canon 16-35 f/4L IS USM |Canon 24-105L IS USM II|Canon 70-300 IS II USM|Canon 100-400L|
pknight
Gallery: 39 photos
Joined Feb 2006
May 22, 2015 07:55 |  #2
It is likely, even if the histogram is not clipped, that you will get more available detail in the shadows and highlights with an HDR image. In Lightroom, the DNG file that is created by three bracketed shots will look exactly like the base exposure (if you don't check the Auto Tone box), but once you start adjusting the settings in the Develop module, you will find that you can recover a lot more highlights and open the shadows much more with the HDR image than you could with the base image.
Digital EOS 90D Canon: EF 50mm f/1.8 II, EF 50mm f/2.5 Compact Macro, Life-Size Converter EF Tamron: SP 17-50mm f/2.8 DiII, 18-400mm f/3.5-6.3 DiII VC HLD, SP 150-600 f/5-6.3 Di VC USD G2, SP 70-200 f/2.8 Di VC USD, 10-24mm f/3.5-4.5 DiII VC HLD Sigma: 30mm f/1.4 DC Art Rokinon: 8mm f/3.5 AS IF UMC
repete7
Gallery: 10 photos
Joined Nov 2010
May 22, 2015 10:37 as a reply to  @ pknight's post |  #3
Thanks for the explanation. Once I played around with the what I thought was a well-exposed base exposure vs the Lightroom CC HDR DNG, I could see a lot less noise in the shadows in the DNG. (Wow, lots of acronyms in that sentence, sorry).
Kolor-Pikker
Post edited over 8 years ago by Kolor-Pikker. (3 edits in all)
May 22, 2015 14:25 |  #4
Due to the way the RGB color space works, the closer any color is to being pure white or black, the less values exist to describe that color.
For instance, in 8-bit RGB (0-255), how can you accurately pinpoint the shade of red near pure white? Red would have to be:
R - 255; B - 250; G - 250
Which means you only have a handful of numbers to describe the shade of red before it loses saturation and becomes white. This is in opposition to the real world, where an object can simultaneously be extremely bright, but also be of a very intense and saturated color.
While the 14-bit register of Raw files has a heck of a ton more numbers to work with, in practice colors will always lose saturation and be less accurate if you recover them vs. getting the actual tone recorded with an appropriate exposure.
I want to point out that this has absolutely nothing to do with ETTR as long as you don't go too far and end up having to recover highlights, carry on ETTR'ing as usual. Cameras use logarithmic tone scaling, while processed images are linear, only the former benefits from a brighter exposure.
5DmkII | 24-70 f/2.8L II | Pentax 645Z | 55/2.8 SDM | 120/4 Macro | 150/2.8 IF
I acquired an expensive camera so I can hang out in forums, annoy wedding photographers during formals and look down on P&S users... all the while telling people it's the photographer, not the camera.
ejenner
Gallery: 98 photos
Joined Nov 2011
May 26, 2015 23:01 |  #5
I sometimes just use the best ETTR exposure that hasn't clipped the highlights, sometimes use the same but merge in a longer expossure for the shadows - just to reduce noise and sometimes put the whole lot into an HDR program anyway.
As to what to keep, it depends on how good the image is and how unique. I'm used to deleting a lot of raw files, but if it is from a vacation, I usually wait 6 months before doing my final cull (before that I will delete anything I can't be bothered to process). So if I took a 5 shot bracket and liked the image I'd keep all raws around for at least 6 months. If I thought I might ever print it, I'd keep all raws and archive them just in case.
Edward Jenner
5DIV, M6, GX1 II, Sig15mm FE, 16-35 F4,TS-E 17, TS-E 24, 35 f2 IS, M11-22, M18-150 ,24-105, T45 1.8VC, 70-200 f4 IS, 70-200 2.8 vII, Sig 85 1.4, 100L, 135L, 400DOII.
http://www.flickr.com/​photos/48305795@N03/ (external link)
https://www.facebook.c​om/edward.jenner.372/p​hotos (external link)
Higgs ­ Boson
Jun 06, 2015 07:03 |  #6
I keep everything forever.
A9 | 25 | 55 | 85 | 90 | 135
rrblint
Gallery: 84 photos
Joined May 2012
Jun 24, 2015 23:13 |  #7
Higgs Boson wrote in post #17586226 (external link)
Me too.
Mark
4,115 views & 0 likes for this thread, 6 members have posted to it and it is followed by 2 members.
1088 guests, 110 members online
