Thread started 26 May 2015 (Tuesday) 14:22
5D Mark 3 HSS
jeffdaypdx
Joined Jan 2013
May 26, 2015 14:22 |  #1
My Mark 3 shutter speed defaults to 200 when I am attempting to shoot using the Mini and Flex for speedlights. Is there an over ride somewhere? I have searched my manual and the web but Can't find it!
Jeff
5D MarkIII | 17-40L | 50L | 85L | 70-200L
jeffdaypdx
Joined Jan 2013
May 26, 2015 14:45 |  #2
I found the external flash area (settings on mark3) but I can only set to HSS when the speed light is on camera, it is grayed out when the speedlight is hooked up to the Flex and the mini is on camera.
Does anyone use a Mark3 and a canon flash for HSS?
Thanks!
abbadon31
Gallery: 264 photos
Best ofs: 10
May 26, 2015 17:27 |  #3
jeffdaypdx wrote in post #17572086 (external link)
Thanks!
Sorry I have no info on the pocket wizard line I only have 1 PW2.
I use the CellsIIC to get my HSS and it works like a charm everytime no misfires.
I AM SHOM
jeffdaypdx
Joined Jan 2013
May 26, 2015 17:30 as a reply to  @ abbadon31's post |  #4
I don't think this is a PW thing, but a canon Mark 3 issue......
OceanRipple*
Joined Dec 2014
Post edited over 8 years ago by OceanRipple*. (2 edits in all)
May 26, 2015 17:30 |  #5
Um, I use Odins which make HSS from a 5D III easy too.
Have you tried the PW Wiki pages or the PC software that comes with the Mini & Flex?
http://wiki.pocketwiza​rd.com …p?title=Canon_5​D_Mark_III (external link)
Also:
"If you are using a Canon flash as an on-camera flash, attached to the transmitting radio, the Master flash needs to be set to HSS via the flash's menu. It is not necessary to set remote Canon flashes to HSS." from PW.
abbadon31
Gallery: 264 photos
Best ofs: 10
Post edited over 8 years ago by abbadon31.
May 26, 2015 17:35 |  #6
jeffdaypdx wrote in post #17572297 (external link)
Make sure all your contacts on the hotshoe are clean, that's the only time I had a problem with getting into HSS on my 5D MkIII
I AM SHOM
King22
Joined Dec 2013
Post edited over 8 years ago by King22.
May 26, 2015 17:49 |  #7
The YN622Cs pass HSS to the receiver with the 5D3
EDIT try looking in the flash settings on the 5D3 when the trigger is on to see if you can set it to HSS.
7D| Σ 50mm f/1.4 | 24-105 L
jeffdaypdx
Joined Jan 2013
Post edited over 8 years ago by jeffdaypdx.
May 26, 2015 17:58 as a reply to  @ King22's post |  #8
First of all thanks for the info, I am trying to learn all this so I appreciate it.
So there are others out there that have a canon 5d mark 3, Flex and mini triggers and Canon flashes and are able to shoot with faster than 200 shutter speed?
I have the canon 580 EX II set to HSS, I set my shutter speed on my mark3 to 1000, but when I push the shutter it shoots at 200.
I can do HSS only if the flash is on the camera.....whats the point of that, I need off camera flash
/Frustrated
jeffdaypdx
Joined Jan 2013
May 26, 2015 20:22 as a reply to  @ jeffdaypdx's post |  #9
Ok so I updated the firmware for the Mini tt1 and config'd it for my Mark III, seems have fixed the issue, can fire it above 1000 shutter speed..
Thanks for the helps everyone...
1,764 views & 2 likes for this thread, 4 members have posted to it and it is followed by 3 members.
5D Mark 3 HSS
1323 guests, 168 members online
